Old 12-23-2006, 04:04 PM   #31 (permalink)
yoshi's Avatar
Default Re: Mini rail buildup...
Originally Posted by f1prerun\";p=\&quot View Post
Thanks Rorty, means a lot especially because you are so negative toward Yoshi * . *HAHA j/k. *I put the front bumper at an angle to give it a different look just like the rear; how that sits up instead of just flat. *Yoshi, I'll try to put the car on a scale later this week, it is light enough where 2 of us can carry it but that doesnt say much.
I don't know the exact weight of my frame, but my employee and I picked up my 400 ex first last night (which weighs 400 pounds) then lifted the bare chassis up and it feels about the same, so I can only assume the frame is between 4 and 450 but I do need to weigh it, we thought it will feel alot heavier...
www.sinistersandsports.com
Old 12-23-2006, 04:39 PM   #32 (permalink)
Admin
Gene's Avatar
Which way you gonna install the "good" lookin' side of that rack adaptor?
Why so many changes on the suspension? Just seeking max travel and ideal camber/bump?
I'm working on mine this weekend too. MERRY CHRISTMAS!
Old 12-23-2006, 06:02 PM   #33 (permalink)
I will get you the weight as soon as I can....If I have to go buy another scale to do it I will or if I have to I'll run over to one of the King's houses (king shocks) to grab the scales and give you an exact measurement. *Gene the top in that picture is that actual top of the rack adapter and is the same way as yours is too. *I dont really know why I changed the suspension so many times, I must have just been bored on a few different nights. *The last time was that I wanted my car to be 76" wide at ride height, well I was looking at the drawing and it was set at 76" at full droop so I changed that, changed the pivots on the uprights and tweeked a few other things. *Right now the front is set at 24.5" travel, I know I will probable limit it one day, .0059" (1/200") bumpsteer through the travel, 76" wide, 5* camber change, 6* caster and 6* rake. *Gotta go do some shopping...Merry Christmas
f1prerun is offline   Reply With Quote
Old 01-01-2007, 01:00 AM   #34 (permalink)
Well today I spent most of the day giving my car a bath in wd-40...other than that, I mocked up where the pedals are going to go. *I have the bottom plate all drawn up and its over at the laser cutters. *I need about a 10.5" pedal and the shortest ones CNC makes is a 12 which I have. *I need the pedals to be 1.5" up from where they are now and about 1" out from each other so I am going to cut apart the assembly, put to breaks in each pedal and weld on 2 new pedals.... *Hope everyone has a safe new years.
