This suspension topic has some GREAT insight. 2.0 bypasses are going into my car very soon.
Justin
Results 161 to 165 of 165
07-16-2019 02:44 PM
Nowhere near the desert.
- Join Date
- May 2019
- Location
- California
- Posts
- 84
07-19-2019 01:31 AM
Side question for you, where did you get the splined shaft that fits the QC gears? That's a pretty sweet gearbox you made to change direction and connect your drivetrain.
Thanks
Sent from my SM-G900V using Tapatalk
- Join Date
- Nov 2009
- Location
- Coos Bay, 10 miles from the OREGON DUNES!
- Posts
- 2,154
07-19-2019 01:02 PM
- Join Date
- May 2019
- Location
- California
- Posts
- 84
07-20-2019 02:23 AM
- Join Date
- Nov 2009
- Location
- Posts
- 2,154
09-06-2019 02:12 PM
Well the last run for the year when well... The flutter stacks in the Bypasses def helped going over the chop! Swapping in the lighter tended spring helped.
But I'd like how much preload I had to put in to get the ride height level ish. The 250lb tender is really stacked up. And I had to move the cross over way down to avoid semi harsh bottom outs.
I should have dialed up some more comp. tube but ran out of time. I think a 300-325lb tender (500mains) would be better, I had the 250lb springs so this whole swap was free besides labor.
All in all I got some good improvements. Its starting to float the whoop trails. That twinturbo Veee8 is really sweet, I might be getting closer to turning it UP... more boost in top gear would be real sweet. The tuning was mucho better NOT hitting 130%VE at 0psi. Coolant temps are better but I'm seriously thinking about an OIL COOLER, oil dips a bit when really warm.JGSFAB- CNC'n everything I can. What to see more?
One more buggy build in the mix...
By iflytii in forum Projects in ProgressReplies: 234Last Post: 08-06-2019, 04:31 PM -
My First Buggy Build
By HaydenP in forum Show off your toys in here!Replies: 9Last Post: 10-08-2012, 12:12 AM -
my first buggy build. we call it the buggy on a budget
By brooksie2113 in forum Projects in ProgressReplies: 26Last Post: 08-20-2011, 09:40 PM -
New Guy, Not a buggy but its my build
By Graham1728 in forum The Welcome MatReplies: 3Last Post: 09-22-2010, 10:51 AM -
very first buggy build
By tnbuggy in forum Projects in ProgressReplies: 16Last Post: 05-26-2008, 01:56 PM
