Page 24 of 24 FirstFirst ... 14 22 23 24
Results 231 to 236 of 236
    Re: Yerf ninja build
    Aug 2016
    Leander, TX
    It's alive! Engine is running now. Wasnt getting fuel so I put a vacuum on the petcock (hey, that sounds dirty) and fuel started flowing. Must have had a stuck float cause fuel went everywhere. I pulled the carbs and dropped the bowls but didnt see a problem. I put them back together and problem had gone away.
    I put the carbs back on and tried to start it and it was fluid-locked. Oh shit. So I pulled the plugs and turned it over and shot fuel everywhere out the spark plug hole. I vacuumed the rest of the fuel out and let it sit overnight with the plugs out. Also I drained the oil but it didnt smell too bad so I put it back. Today put the plugs back in, hit the choke and the starter and it fired right up. Revs smoothly and idles fine. Only issue is it's smoking a bit. I'm thinking maybe a stuck ring. I might try some Seafoam or something.
    May 2013
    Easton, PA
    might have washed the cylinders with all that fuel sitting on top, those old carbon buildup rings on the walls at the top of the stroke hide worn walls/rings a lot of times. clean them off and here comes ol smokey.
    Aug 2016
    Leander, TX
    Its running great now. No smoke. Maybe just some burnoff on pistons. Who knows. Hopefully it doesnt come back.
    I wanted to take it for a ride around the neighborhood today but ran out of time because apparently I'm retarded. Got it all ready to roll, started it up, put in gear and it shuts off. Mucked with it for hours. Long story short I just needed to tie the kickstand switch wires together.
    Anyway it works fine now so I'll try to take it out tomorrow. Cant get too crazy cause I still dont have chain tensioners. Waiting on some tensioner wheels from China. I mounted the driver's seat and 4 point belt. Had some interference on passenger side belt mounts so I'll need to remake them. Drag.
    Feb 2009
    Baton Rouge area
    Just read the whole thread. Great build. I am going to steal a couple of ideas. good luck with the test drive.
    Aug 2016
    Leander, TX
    thanks, but dont do swingarm suspension like I did. Go for CV joints. I might retrofit mine at some point.
    Feb 2009
    Baton Rouge area
    Funny you say that... i was olanning on doing swing arm on my sons buggy. Maybe i will reconsider
  1. My Yerf Dog Spiderbox
    By mikesova in forum Show off your toys in here!
    Last Post: 01-13-2014, 08:08 AM
  2. 900 ninja buggy build
    By buggymane in forum Projects in Progress
    Last Post: 03-18-2013, 10:20 AM
  3. First buggy build . ninja 600 any help or advice welcom
    By xd2cx in forum Projects in Progress
    Last Post: 10-02-2012, 05:13 AM
  4. just got a 600 ninja want to build a rail out of it
    By peterpan in forum MiniBuggy.net Lounge!
    Last Post: 05-02-2010, 10:42 AM
  5. Ninja powered buggy build
    By mdune_100 in forum Projects in Progress
    Last Post: 04-07-2010, 07:50 AM
