Page 3 of 35 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 342
    Re: JGSFAB 2-seat Turbo GSXR1000 buggy build
    #21
    I had thought about leveraging a flex joint between the engine and transmission (FNR), but have wondered about getting the correct alignment of the FNR input shaft to the engine output shaft. For the stickshift muscle cars I have built, I dialed in the bellhousing input shaft bearing pilot hole to the engine crank using offset dowels and dial indicator. Also checked for perpendicularity to the flywheel. That works fine when you have the two mounted to each other. It's different when the transmission is not attached to the engine. One is for the initial setup/alignment, the other may be with dynamic loads causing the joint to flex between the engine and transmission. Needless to say, I am curious as to how you mounted the FNR and what alignment adjustments you did to set it up. Might help me with the design I am thinking about.
    #22
    Bend-Tech Dragon Master
    Nov 2009
    The FNR mount is shown in the pics and is 3 axis adjustable. The bimmer flex disc will account for any misalignment during frame flexing . We will see how this one goes, the flex should save gears, reverse chain, etc.
    Lots of newish little things in this car
    #23
    Yup, that's the same thing I was thinking of doing. Setting up 3 axis adjustments to allow for proper alignment and locking it in after that. Are you using jack screws to make the adjustments? Maybe there were pics earlier in the post, but I missed them...
    #24
    Nov 2009
    Quote Originally Posted by NinjaRaptor View Post
    Careful hammer taps
    #25
    Nov 2009
    Ready to weld up the driveshaft
    Bedlined the cell shell, the red paint doesn't last long.
    #26
    Impressive JGS
    Are you going to run 930 cv's if you are BMW make diff flanges that suit the 930 cv's
    Just pop out the ones you have and pop in the 930's type
    Have you thought about using CV's for the drive from the engine to your FNR box ?
    Another option up your sleeve . I used uni Joints on 1 build and had vibration problems
    Which had a couple of issues 1 was no slip in the set up (thermal growth) and the other issue was I had much more miss alignment than you have
    #27
    Nov 2009
    Quote Originally Posted by whitedragon64 View Post
    Impressive JGS
    I did build in a small amount of slip to get the shaft in place (my FNR has square splines like most slip sections). Glad its going to be functional too.
    20deg shaft angle, its not bad.
    I briefly thought about CVs but I machined the shafts with splines that match off the shelf u-joint parts. There is even a cheap 4 bolt flange from an early Jeep T-Case.
    The axles and drive shafts are finished already, F150 outers all around and I came up with this mod for the inner....
    Apparently I never posted pics of the finished ones Which Bimmer model is the 930 size?
    #28
    I think some 5 series and some 7 series with the 6 cyl diff in then
    A mate had the diff lying around so I grabbed it and it was the 6 Cyl size and had the large flanges hanging off it , That's all I used of the diff
    #29
    You are making good progress, look forward to seeing pics of the overall drive train once its completed.
    #30
    Nov 2009
    Pedal/steering cluster.
  1. ProtoLite SS 1000-new 2 seat build
    By ProtoDie in forum SS1000 - Two Seat Race Buggy
    Last Post: 04-04-2018, 02:36 PM
  2. JGSFAB 4 seat midibuggy build
    By JGSturbo in forum Projects in Progress
    Last Post: 02-23-2015, 02:09 PM
  3. 250 Buggy First Build
    By PsYc0TiC in forum Projects in Progress
    Last Post: 04-14-2013, 08:18 AM
  4. Plans for a 2 seat buggy to buy?
    By kaslie in forum How To Do It
    Last Post: 09-04-2012, 02:25 PM
  5. Similar buggy to build like the blitz world kr2
    By cassidyni in forum MiniBuggy.net Lounge!
    Last Post: 05-03-2012, 07:55 PM
