Page 24 of 24 FirstFirst ... 14 22 23 24
Results 231 to 238 of 238
    Re: Mini Trail Buggy Build
    Nice work. I like the hangers - they look like holy bananas.
    What are the mufflers off of?
    I missed the whole thing on the fiberglass panels - that looks really good. The stuff is a mess to work with, isn't it. Did you do weave everywhere or did you throw in any kitty hair? They should be pretty bullet proof.
    Senior Member n1kogr's Avatar
    Jan 2012
    Massachusets
    thanks k-fab yea working with the fiberglass kind of sucks i did 2 layers of thick mat then a layer of the mesh and it came out pretty good needs body work to bring it somewhat smooth but im not too picky its going in the woods not a car show. But it seems pretty strong i was also surprised at how much i can flex it.
    Anyway the mufflers are off of a 2007 honda crf250r i used the factory tubing where they clamp on so my plan is to find a used set of aftermarket pipes that will bolt right on.
    Feb 2009
    Baton Rouge area
    Dang, that exhaust looks pretty cool coming out the back. And i like those mounts. Good job.
    Quote Originally Posted by n1kogr View Post
    You should be good - the stuff is remarkably strong and they way you layered it will flex but not crack unless hit.
    I started to ask if they were 250 or 450 CRF. Go look into the FMF Q-pipes. They add low end torque (at least on the bikes) and are quite a bit quieter. They make a nice sound.
    Jan 2012
    Massachusets
    well after a quick impulse buy i had to make these. 4x156 to 4x110 wheel adaptors now i have 4x110 all around.
    Jan 2012
    Massachusets
    Wiring pretty much done. I made a quick little firewall out of .060 stainless and used some rivnuts to mount to the frame. Also re cut a new dash out of the same .060 stainless. Its finally nice to see it coming together
    Feb 2009
    Baton Rouge area
    How does the Vapor measure speed? Is there a sensor by the wheel or ?
    Jan 2012
    Massachusets
    Quote Originally Posted by Wheels View Post
    The kit comes with a magnetic sensor and a bolt with a strong magnet on the head of it. The bolt is meant to replace one of the front disc brake bolts then you mount the sensor on the factory dust shield a bit of calibrating after that and your are done. Very easy to do and for the price of the vapor i love it i have rpms, speed, coolant temp, outside temp, shift light, timer, odometer, and im sure much more. It was just under $100 definitley worth it in my eyes.
  1. My first mini buggy build
    By andy777bmx in forum Show off your toys in here!
    Last Post: 02-14-2013, 04:52 PM
  2. trail buggy build
    By herman pahls in forum Motor - Engine
    Last Post: 05-23-2012, 04:35 AM
  3. Mrfreyguy's Mini Buggy Build
    By mrfreyguy in forum Projects in Progress
    Last Post: 01-27-2012, 02:00 PM
  4. Mini A Arm Buggy for Kids
