Old 02-13-2010, 02:48 AM   10 links from elsewhere to this Post. Click to view. #1 (permalink)
daaboots's Avatar
Default Homemade pipe bender
A few people have asked for pictures of my homemade pipe bender, so here they are - finally!
I made the shoe by hand on a lathe. The grove isn't a perfect half circle, but it's close enough for me.
Nothing too fancy... does the job.
Old 02-13-2010, 03:01 AM   #2 (permalink)
nutz4sand's Avatar
Default Re: Homemade pipe bender
Completely designed by yourself? Thats pretty neat and a neat concept/methoed!
Is that a full on 90 degrees it will bend? Looks great for a homemade bender if it does what you need!
Oh look! A bunneh!
Old 02-13-2010, 11:45 AM   #3 (permalink)
daaboots's Avatar
I serached the web to get ideas from other homemade benders, but in the end it was my design. Yes, it does full 90 degree bends... kinks a little, but not too bad.
Old 02-13-2010, 12:55 PM   #4 (permalink)
Martinm210's Avatar
Awesome, thank you!!
Martinm210 is offline   Reply With Quote
Old 02-13-2010, 04:14 PM   #5 (permalink)
yoshi's Avatar
The kinking is from the material your using, not the bender..
www.SinisterSandSports.com ............................................918-521-3736
.................Yes, i'm on facebook clicky clicky.................
Old 02-13-2010, 04:25 PM   #6 (permalink)
Bullnerd's Avatar
I think theres a thread on OFN where a guy split a lenght of tube and layed it in his die to make the next size smaller.You might be able to do something similar on your bottom die.Just replace the angle with a lenght of split tube and support it really well right up to your bending die.It may support your tube better and remove the kinking.Hard to explain with my sorry azz typing.
found it.http://www.rockymountainextreme.com/...ad.php?t=64205
also after looking at your pics again i see the "follower" isnt under the center of the die?This is your problem.If you add this split tube mod and put it on some simple rollers,you'd have a sweet bender.
I'll find some more pics of what i mean.
"Life's tough, it's even tougher if you're stupid!"
~John Wayne~
Old 02-13-2010, 04:33 PM   #7 (permalink)
nutz4sand's Avatar
If you look at the very first pic of the die it looks like its got a tiny bit of a sorta flat spot at the bottom of the radius. I might wonder if that is adding to or causing the kinking?
Oh look! A bunneh!
Old 02-13-2010, 04:48 PM   #8 (permalink)
Bullnerd's Avatar
See how the follower rides on a roller.
Pipe Bending Machine & Equipment, Tube Notchers, Bead Rollers
~John Wayne~
Old 02-13-2010, 05:42 PM   #9 (permalink)
1yldryd's Avatar
I built a bender alot of years ago, no hydraulics just a long handle. I still have it and used it to make a rack for my 05 honda vfr 800 a couple years ago. When I started bending mild steel tubing it was just to hard to use and the aluminum dies started showing wear so I bought the Pro Tools 105 2 years back and it works well.
some of my old dies, benders buried around here somewhere
1yldryd is offline   Reply With Quote
Old 02-19-2010, 12:40 PM   #10 (permalink)
daaboots's Avatar
Yeah i realize that the die isn't perfect. At the time I didn't know how to cut a nice half circle into the die (still don't ). The angle at the bottom is actually pulled in as the pipe is bent. This provides the support under the die as it rotates.
I like the idea of the larger tube instead of the angle... might try that someday.
Your dies look really nice 1yldryd. How did you make them?
LinkBacks (?)
LinkBack to this Thread: http://www.minibuggy.net/forum/projects-progress/12578-homemade-pipe-bender.html
Posted By For Type Date
pipe bender homemade - Info.com This thread Refback 02-11-2013 10:18 PM
Homemade Pipe Bender This thread Refback 02-09-2013 01:14 PM
Home Made Pipe Bender This thread Refback 02-08-2013 11:59 AM
Homemade Pipe Bender - info.com.au This thread Refback 01-19-2013 07:34 AM
Pipe bender This thread Refback 12-16-2012 01:05 PM
Pipe bender This thread Refback 12-11-2012 11:46 AM
Pipe bender This thread Refback 12-10-2012 04:27 AM
Pipe bender This thread Refback 12-09-2012 03:20 PM
Pipe bender This thread Refback 12-09-2012 02:51 PM
Homemade Pipe Bender | www.Bizplenty.com This thread Refback 03-19-2011 12:55 AM
Need Quick Help on Pipe Bender toopilot Frame 4 12-31-2009 09:05 PM
Pipe Bender Preference bigdreams467 Shop Talk 1 01-16-2009 02:13 AM
OHH NO!!!! Another HF Pipe Bender Thread boostick4 Shop Talk 7 10-09-2007 05:06 AM
ATTN:... harbor freight pipe smasher fix!!!! voodoochikin04 Shop Talk 13 10-04-2007 05:38 AM
