Old 10-27-2009, 04:27 PM   #1 (permalink)
daaboots's Avatar
Default David's Edge Trax 2 build
Well I started on my second build recently. It's an Edge Trax 2 for my wife. Here's the pics so far...
Working from the plans is very nice. I almost wish I would have bought plans for my first buggy. Oh well
Progress is going very fast. I'm hoping to have it done for Christmas.
Old 10-27-2009, 06:08 PM   #2 (permalink)
Default Re: David's Edge Trax 2 build
Do a search on jwcarguy he has pics of his buggy and you can see his suspension.
Old 10-30-2009, 06:56 AM   #3 (permalink)
Can you show some pics of your bender? I have a jd2 bender but i don't want to spend another $300 for a one inch die.I have all the stuff to make a bender like yours for 1 inch tubing. But im not sure how you clamp the tubing to the die. It looks like your using a Gate roller wheel. Nice setup. It doesn't look like it kinks much either. You can also cut a piece of 1.25x .120 tubing in half and weld it onto the angle iron to cup the tubing better.
rgvkid is offline   Reply With Quote
Old 10-30-2009, 07:00 AM   #4 (permalink)
looking good!
87 tecate 4
83 hoda odyssey fl250
ruthlessxbeastx is offline   Reply With Quote
Old 10-30-2009, 05:08 PM   #5 (permalink)
Good luck on the new build David
I'd say someone went to princess auto for a parts run It's a great place to blunder around for an hour or so I think the wife will have a blast with it . Good luck on the build keep us posted
How are edge plans ? everyone that has a set seems to think there great
Later Sodman
sodman is offline   Reply With Quote
Old 11-02-2009, 01:43 AM   #6 (permalink)
daaboots's Avatar
It's just a home made bender, nothing fancy. I'll try and get some pics for you if I remember.
Old 11-02-2009, 01:47 AM   #7 (permalink)
daaboots's Avatar
Later Sodman
Yes, I'm a big Princess Auto fan, but I actually buy most of my parts from a company in the US because of the price difference.
The Edge plans seem ok. There were a few things that could have been done different. I've never worked with plans before so I cant really compare them to anything.
Take care Sodman.
Old 11-02-2009, 01:59 PM   #8 (permalink)
Short Circuit's Avatar
Looking forward to this build as I thoroughly enjoyed your first one
Mark
Short Circuit is offline   Reply With Quote
Old Yesterday, 01:43 PM   #9 (permalink)
daaboots's Avatar
Update:
First of all, I picked up this old Honda 4-wheeler for $150 to use for parts! The top end of the motor is done, but I plan to use the rims, tires, and front suspension. It has hydraulic drum brakes on the front which should work great on the buggy! I'm hoping to use the front swing-arm suspension, but I'm not sure how that will fit on just yet.
Found a really nice seat for the buggy. Made some real good progress on the rear end. I moved the axle back some, and made it wider. The rear end will be close to 52" wide when I'm done. I would have gone wider, but then it wouldn't have fit in the back of my truck box. I added some extra brace for the axle to support the extra width.
Brake mount is finished, along with the motor mount.
Next, I'm going to get the seat mounted, and then start working on the front suspension.
Old Yesterday, 09:32 PM   #10 (permalink)
How's it going David
I see that the buggy is starting to come forward. That swing arm looks close to or identical to the swing arms that the FL 250 odyssee's used I have one setting in the shop that I was going to bring back to life some day but the the sabertooth took over.(needs a motor) Some of the odysee guys on here could give you pointers I would imagine. Good luck on the build
Later Sodman
Sandrail build tips, tricks, and stuff learned the hard way. yoshi Shop Talk 41 07-11-2009 05:48 PM
Mini Truggy (TK) Build moneypit Projects in Progress 11 03-10-2009 07:45 PM
Edge Barracuda build. Mike Projects in Progress 56 03-26-2008 01:04 AM
SHEARER INSANITY BUILD! Racerj404 Projects in Progress 115 10-25-2007 12:01 AM
Best plans for first build? Nobody077 Frame 13 02-21-2006 02:59 PM
