#21 (permalink) |
Thanks Daaboots - im off to the garage now to do some more work on it!!!!
ChaosMS From Chaos comes Creativity......... http://www.chaosmotorsport.com Home of the Ultralite Buggy! |
#22 (permalink) |
Well ive been busy again!!
![]() ![]() got all the rear suspension mounted up this weekend / today - re done the lower shock mount so that it would clear the new rims I have for the project and finally dropped it onto the floor with two steel wheels (from the donor car) - which turned out to be a waste of time so I took em of again! Anyway a few shots for you all :- View of rear suspension showing shock location and new hub top mount (lower mount finished and now in primer- ![]() View from rear showing all suspension and shocks (shock upper mounting hoops not done yet) ![]() Side view with one of the new rims bolted on ![]() Rear view with rim ![]() Well I hope you like the shots, I think its starting to look the part now, I have a couple of days off work now (took some holiday) so I aim to get the front suspension sorted (it would be nice if I could get it done by the end of the week !!
#24 (permalink) |
XRH348 - the hubs are from a suzuki swift car - a humble 1litre version! - I have 4 of them (2 sets of fronts) eventually they will be fitted with 10 inch vented disks, I have made adaptors to change the suspension geometry from a lower arm and mcpherson strut to dual A arm all round - seems to function well at this early stage
#27 (permalink) |
Daaboots - thanks !! - the buggy will indeed be street legal, I was going to put it through as a heavy quad bike but the finished weight of the buggy now forces me to put it through as a car (In the UK if the power is restricted and the weight is up to 400kg it can be classed as a heavy quad bike, however at the last project weigh in it was obvious that I was not going to keep it under 400kg and the finished weight was going to be around 475kg)
The shocks are custom built from a comapny called AVO here in the UK they are 30 inches long and have approx 11 inches of travel - and they are adjustable Kawonda - thanks for the comments - i will keep the pics coming!! Just finished preping all the parts for the front suspension - all bending cleanup cutting to length etc - and tak welded the first two front suspension arms together! pics to come soon
ChaosMS From Chaos comes Creativity......... http://www.chaosmotorsport.com Home of the Ultralite Buggy! Last edited by ChaosMS; 11-12-2009 at 06:16 PM. |
#28 (permalink) |
Well been busy the last few evenings and managed to get the 4 front arms built just tacked together at the moment but should get chance this weekend to finish them and fir the rose joints!
- I also managed to get the vertical mounting tubes in place for the front suspension, so got a couple of pics for you :-the 4 front arms built (but not finished quite yet: ![]() And the front verticals in place ready for the suspension: ![]() I hope to get the arms and mounting tubes fully welded this weekend and also go some way to mounting them up!! ![]()
| Not a buggy, but my Busa powered project | turbomatt | Show off your toys in here! | 17 | 08-22-2009 10:48 AM |
| Need help picking motor for onroad/offroad buggy project | r00st | Motor - Engine | 6 | 08-11-2009 01:52 AM |
| My new buggy/ kit car project | LEE1969GB | Projects in Progress | 34 | 01-07-2009 01:22 PM |
| Buggy Project | Odyknuck | Show off your toys in here! | 7 | 07-11-2008 06:43 PM |
