Old 05-03-2009, 09:31 PM   #1 (permalink)
Default ecotec build
Heres some shots of my build, I came up with this design on my own from other buggys and side by sides, I would like some input, good or bad, I used 1-1/4 dom 120 wall, this may be an over kill? It seems heavy and this is my first time building a frame this big? the tube was free so I used it for bracing also.
moto1 is offline   Reply With Quote
Old 05-03-2009, 10:22 PM   #2 (permalink)
nutz4sand's Avatar
Default Re: ecotec build
With an ecotechs torque to push it the 120 wall aint a bad thing. Might save your bacon if you ever crash it bad then it will be a VERY good thing. Specially if its (the tubing)FREE! Looks pretty good so far.
Sand! The only gold I need!
Old 05-03-2009, 10:59 PM   #3 (permalink)
Here are some pics of the bracing, also the RPM gear box, and eng mounted. The motor mounts are adjustable, I can move the eng forward or backward and side to side about 1.5" . I will take some good shots of the motor mounts, this should help for cvt alignment.
Old 05-03-2009, 11:48 PM   #4 (permalink)
Admin
Gene's Avatar
Looks good to me. Car has some nice lines.
Old 05-04-2009, 12:22 AM   #5 (permalink)
nice work
deviant_illusion is offline   Reply With Quote
Old 05-04-2009, 12:48 AM   #6 (permalink)
Thanks Gene, thanks deviant.
Some photos of the motor mounts, please speak up or comment about the mounts?they will slide in any direction when loose, and to raise I would need to shim. I would use older chevy front end alignment shims, they come in all sorts of sizes or thickness. Neil at atv racing says to get the two shafts (drive flang shaft & RPM shaft) within 5 thousands in any direction, I have already played with the motor mounts and it seems to work well so far. also a shot of parts from Neil.
Old 05-04-2009, 03:56 PM   #7 (permalink)
Very clever and functional on the range-of-adjustment on those mounts!
Radiodude is offline   Reply With Quote
Old 05-04-2009, 08:27 PM   #8 (permalink)
I like your mounts. I am almost ready to mount the engine in mine and may do something simular. Did you make them yourself?
furtelli is offline   Reply With Quote
Old 05-05-2009, 03:27 AM   #9 (permalink)
Yes I did make the mounts, the double grove angle iron I had just laying around.
moto1
Old 05-05-2009, 05:31 AM   #10 (permalink)
I have never heard of double groove angle iron. Are you concerned about the engine sliding around after it is cinched down?
Sandrail build tips, tricks, and stuff learned the hard way. yoshi Shop Talk 41 07-11-2009 04:48 PM
Bens mini sand rail build QLD, AUSTRALIA.. benb1984 Projects in Progress 19 12-24-2008 06:26 PM
SHEARER INSANITY BUILD! Racerj404 Projects in Progress 115 10-24-2007 11:01 PM
Input Wanted for my next build. TutTech Projects in Progress 21 07-06-2007 05:07 AM
Best plans for first build? Nobody077 Frame 13 02-21-2006 01:59 PM
