Old 02-08-2009, 05:25 PM   #1 (permalink)
Default FFJosh R1 Rhino build
Finally getting ready to start some major work on this thing.
Going to be using a 03 R1 Street Bike engine.
What I Started with. I bought a blown up 04 Rhino from a local shop.
stripped the thing down to nothing
using a rear carrier from Yoshi.
I am kind of at a stopping points. Debating on hacking off the rear end and starting over...or using the existing frame.....I am leaning towards hacking it off to make life easier
ffjosh is offline   Reply With Quote
Old 02-08-2009, 06:58 PM   #2 (permalink)
Default Re: FFJosh R1 Rhino build
I am working on a very similar project mine is a 05 rhino with an SV650 engine going in. I have talked a little with you on here I decided to use parts from Jody at Protodie I bought his rear hub/spidles and center section. ( Thanks to Yoshi sorry I did not buy your parts this time but I do appreciate you taking time to try and work something up for me.)
I have been looking at the rear end a lot also and I believe I am going to cut the top section off and tie the stock rear a-arm mounts into the cage going back towards the bumper. I plan to start my own project page here later today probably good luck on yours I hope it turns out well. Dont be mad if I steal some ideas ha ha I am very new to this but I really have high expectations and am really looking forward to the project.
adubaz7 is offline   Reply With Quote
Old 02-08-2009, 07:26 PM   #3 (permalink)
I am pretty new to this too. I have helped SAS some trucks, but this is a complete new ball game. I am even making my own a arms.......talk about jumping in with all feet. I just can't justify spending 4k on a aftermarket set.
I have a couple plans...
#1 - cut off the rear hitch off and let the sprocket come back further. Then use the stock mounts.
#2, cut the rear end off right before the stock curve. Box it in and run a tube across the back.
Then I can run 2 tubes for frame rails and can bring the frame rails in so I can make longer a arms. I will then move the top a arm mount up a inch so its Parallel with the spindle.
The space between the top mount and lower mount is 6 inches. The space on the frame rail is 5. I would think it would work better if they are both 6. I could be wrong.
There is also 2 inches of space between the a arms mounts. They do not make hiems with spacers like that. So I could make new mounts so i do not need spacers machined.
Here is a pic of what I may do. Hope my rambling makes since
Purple/Red is the bottom rails and the top is the blue. That some paint skills haha
Old 02-08-2009, 07:51 PM   #4 (permalink)
DMO
what are your plans with all the stock running gear??.. have you sold it yet?
DMO is offline   Reply With Quote
Old 02-08-2009, 07:56 PM   #5 (permalink)
I have sold the rear diff, junked the axles, one was broke, I have a front drive shaft and some other misc stuff.
If you need something let me know and I will go see what I have left
Old 02-08-2009, 09:18 PM   #6 (permalink)
DMO
im interested in as much of the drivetrain and suspension you have left.. do you have front diff, axles or any of the suspension ? and where are you located?
Old 02-08-2009, 10:24 PM   #7 (permalink)
Located in northern Indiana.
I have the front diff, front drive shaft, stock suspension, no axles. I may have some stock a arms as well.
Old 02-11-2009, 11:39 PM   #8 (permalink)
Crappy pics but I didn't feel like taking everything off of it since I am not going to work on it today.
Cut off the rear end
Bent some tube
Now waiting on parts
Old 02-12-2009, 06:15 AM   #9 (permalink)
Cool engine mount. LOL Looks like you finaly got her started.
punkur67 is offline   Reply With Quote
Old 02-12-2009, 12:31 PM   #10 (permalink)
LOL, its nice for moving around the shop.
I am going to use part of it though. Makes my life easier
Sandrail build tips, tricks, and stuff learned the hard way. yoshi Shop Talk 41 07-11-2009 04:48 PM
first full race rhino build rhino ron713 Show off your toys in here! 38 01-16-2009 12:55 AM
Rhino build with a small block.. yoshi The UTV Area 1 06-11-2008 03:37 PM
SV1000 RHINO FOR SALE! 22K OBO! CBRhino For Sale 0 10-29-2007 08:55 PM
SHEARER INSANITY BUILD! Racerj404 Projects in Progress 115 10-24-2007 11:01 PM
