Old 01-14-2009, 11:57 PM   #11 (permalink)
Default Re: Building a Desert Stadium Lite
Ya, it's hard to believe that a car that most everyone loves, and yet know body is building it??
nutnbolt2002 is online now   Reply With Quote
Old 01-15-2009, 12:14 AM   #12 (permalink)
Bullnerd's Avatar
Its so obvious!Its driving me nuts!
Old 01-15-2009, 01:36 AM   #13 (permalink)
Super Moderator
TutTech's Avatar
Well not building exactly like that but a little bigger like the Drakarts were and not a arms
on this one as I have tons of front trailing arms for almost free, so I am going to use them. Especially for this size wheelbase and wheel travel that will be fine for now.
I will have more to show tomorrow. Mine will be my own design and unique in my own
way and maybe people may like them. Plus the cost I think will be worth it compared to
a Drakart etc. Depending how mild or wild I build it I think I will have the most mild
car out at first. Making it the most cost effective car out. Who knows.
Thanks Bullnerd.
Fl250driver, Sicksand, jay1823, nutnbolt2002 and David M thanks for the input and feedback also, it's much appreciated.
Tut Tech Racing
Old 01-15-2009, 02:27 AM   #14 (permalink)
Originally Posted by TutTech View Post
What rules do you use? I am using the same rules as Protodie, etc.
In those rules is the SR class I believe it is the open class. Motor size etc. is big but
that will give me the ability to cross over from desert to stadium. Plus get the long travel.
Your class has some restrictions on shocks, wheelbase etc. right?
Hmm I will think on it but because of this guys little bigger size I was thinking I would
need the bigger motor and run in the open class?
So that is why I want the open class.
Or am I wrong as I have never raced just reading rules.
Can you give me a link to the rules you use so I can see if they are the same??
Thank you.
Tut as far as rules go,they are not that strict.I know that we race against a couple drakarts,the formula cross is the one we race against but the Tornado would most likely be to big.You can go to Drakart.com and see the specs.The width and length is still probaly in the range you are looking.The bad thing about you going with that big of motor is that you might be to big for a stadium lite?Like I said,we raced against the drakart at Anaheim and there were no problems.I will also look and try and get the specs for you.That other car that guy posted would be sweet to build and get going again.Maybe we could get a Mickey Thompson series going again?That has been talked about before by someone on here but he was going to want way to much money for them.(just my opinion).I don't know where the rules are,I know before we were just kind of going with all of us being cool with it.I run against the 800 sled engines and I know that on some tracks I don't stand a chance but thats the way it goes,there is short tracks also where they can't use all the power...
sicksand is offline   Reply With Quote
Old 01-15-2009, 02:32 AM   #15 (permalink)
Thanks Bullnerd.
Out of production
The 2002 Formula Cross is the flagship of the Drakart family of off road cars. Over ten years ago the first Drakart off road single seat car was designed, built, and raced in Europe. The fifth generation Drakart Formula Cross sports a decade worth of refinement and performance enhancements.
2000 Formula Cross Review by Dirt Wheels Magazine.
ENGINE
Type Rotax 2 stroke, twin 597cc
Fuel System Dual Mikuni TMX 38mm
Lubrication Fuel premix
Starting Electric with pull start back up
Power 110 HP at 8200 RPM
COOLING SYSTEM
Aluminum radiator and electric fan on thermostatic switch
CLUTCH
Automatic and adjustable CVT centrifugal clutch and high performance belt.
TRANSMISSION
Drakart 3 position gear box (forward, neutral, reverse) with reinforced straight cut gears. The engine can start in any gear position. Final drive is by drive shafts and high angle CV joints.
FRONT SUSPENSION
Double adjustable A arm with remote reservoir coil over shocks. User adjustable spring preload, factory custom valving available, 16” of travel.
REAR SUSPENSION
Adjustable three link providing 16” of travel. Remote reservoir coil over shocks with threaded preload adjustment. Factory custom shock valving available.
REAR BRAKE SYSTEM
Single 4 piston caliper with 270mm diameter ventilated rotor.
FRONT BRAKE SYSTEM
Dual 2 piston calipers with 185mm rotors. 3/4" Master cylinder and stainless steel braid protected silicone hoses.
STEERING SYSTEM
350mm steering wheel mounted to a quick release hub. 3/4 turn rack and pinion.
COCKPIT
Bucket seat with washable vinyl cover, 5 point harness with 3 inch strapping and multi-tubular cage
Front wheels Aluminum 10x5
Front tires Dirt 23x7x10
Rear wheels Aluminum 10x8
Rear tires Dirt 22x11x10
Length 2640 mm 104 Inches
Width 1670 mm 66 Inches
Height 1420 mm 57 Inches
Clearance Front 380 mm 15 Inches
Gas tank 28 Liters 7.4 US Gallon
Weight 300 Kg 660 LB
Call for Price
[Tornado] [Formula Cross] [Tiger]
[Intimidator] [Photos] [Options] [Parts]
[History] [Home] [Terms] [Contact]
Old 01-15-2009, 04:00 AM   #16 (permalink)
Super Moderator
TutTech's Avatar
Oh nice.
Here are the rules I went off.
Class SR-OPEN
Ages 16-up
This class is an open class designed for custom built mini-buggies, highly modified Honda Pilots, Drakarts and Stadium Lites. Maximum wheelbase is 80”, 70” maximum width and maximum overall length of 105”.
R-1. SUSPENSION:
FRONT: Open
REAR: Open
R-2. STEERING: Open
R-3. SHOCK ABSORBERS: Open
R-4. WHEELS AND TIRES: Open
R-5. BRAKES: Four wheel braking system required.
R-6. ENGINE: 600cc two-stroke twin, 1000cc four-stroke max.
I believe your class would normally be this one.
Class SR-2
Ages 16-up Defined as an advanced class single seat mini-buggy. This class is designed for reliability and performance on a modest budget. Wheelbase maximum is 77”, max. width is 68”. This class would allow the mostly stock Honda Pilot FL400 or stock/modified Odyssey FL350.
R-1. SUSPENSION:
FRONT: Swing arm, A-arm or trailing arm suspensions allowed. 10” maximum wheel travel.
REAR: Swing arm, A-arm or trailing arm suspensions allowed. 10” maximum wheel travel
R-2. STEERING: Rack and pinion steering required.
R-3. SHOCK ABSORBERS: Open shocks. Gas/rebuildable shocks
allowed. Reservoir shocks allowed.
R-4. WHEELS AND TIRES: Steel or aluminum ATV style wheels and tires.
R-5. BRAKES: Drum or disc brakes allowed. Four-wheel brakes required.
R-6. ENGINE: 500cc two-stroke twin, 750cc four-stroke maximum.
These rules are from the official rules.
I see the class your running and the difference.
Hmm ok I will think on it thank you for the info.
Tut Tech Racing
Old 01-15-2009, 05:14 AM   #17 (permalink)
Also look at the HOME - CMOOREOFFROAD.COM they have a nice buggy but it might be a little to big?I want to see what you come up with,thats the only way to see what that mind of yours is thinking,lol.Keep the pics coming,and get some damn sleep,lol...
Old 01-15-2009, 12:59 PM   #18 (permalink)
ProtoDie's Avatar
I have to move out West.
Not trying to be a downer, but
All these different brands of cars, and racing specs. Even with no racing specs, we can't get anybody to show up & race (here in the Midwest).
Hope this year is different.
Tut, looking good. I hope your next build can help promote mini buggy racing,,,,,,,,cause I'm tired of just racing 2 other buggies
ProtoLite Race Buggies
Come Race With Us
ProtoDie is offline   Reply With Quote
Old 01-15-2009, 01:05 PM   #19 (permalink)
Jay1823's Avatar
I'm hoping i have mine ready to race this year, you guys are gonna kick my ass but i still want to give it a shot
Jay1823 is offline   Reply With Quote
Old 01-15-2009, 01:09 PM   #20 (permalink)
ProtoDie's Avatar
Sweeeeeeeeet.I may be racing a 2 seater though,,,,so abit slower,,,,we will see.
Come Race With Us
Stadium Lite Design TBD Frame 20 03-15-2010 05:06 PM
Stadium Lite for sale BlueCoyote For Sale 19 02-23-2010 03:54 AM
Lake Elsinore Stadium Lite Race utvfab Events and Group Gatherings 0 05-26-2008 07:42 PM
stadium lite xmotorcr For Sale 6 03-30-2008 01:17 AM
Getting Started on Stadium Lite Rules K-fab Class Development 22 09-19-2007 11:10 PM
