Thread: Jedi Rock Buggy
Results 1 to 10 of 10
    Jedi Rock Buggy
    Well I was going to call it the Ninja Buggy but the boys are into Jedi's now so a new name. Even before I've started building.
    Anyway I'm building a rock crawler buggy for my boys. 6 & 10. I still have a lot of research to do and parts to gather/buy. I still have to pay for the motor (got from a friend) but I have it. I also have the axles, springs and tcase.
    It will be a 2 seater.
    10hp motor
    Suzuki Samurai Axles and t case
    I've been working on figuring out the steering and am curious to see how the Corsa 12 v steering is working.
    Also working on reverse as well. I've looked into the Comet boxes, but some people are on the fence about them and Comet has ceased production and is selling off what they have then no more. Due to my low power I'll most likely go with a Peerless tractor transmission. 4 forward gears and a reverse.
    I'll be getting a comet torque convertor and put the driven wheel on the input of the peerless transmission then direct couple that to the sami tcase.
    I still have gear ratios to sort as well.
    I'll be buiding the chassis myself. Base is to be 2x2 square with a full DOM cage. This will be slow as I have to finish some other projects first.
    I'll update this as I go.
    Re: Jedi Rock Buggy
    Member David M's Avatar
    Aug 2008
    Barstow,Ca
    If you look on Pirate 4x4 they have small rock crawlers powered by Honda motors, on off them is driven by a seven tear old girl.
    Re: Jedi Rock Buggy
    Quote Originally Posted by David M View Post
    Yes I frequent there. I have pm'd him a bunch for help. I like the Honda motor idea, but I don't have one as he did and I want simple and cheap. I don't want to mess with a computer/sensors, plumb all kinds of cooling, etc. I may come to regret this decision but such is life.
    Re: Jedi Rock Buggy
    I think your going to need to gear down a ton for that 10hp motor to be able to turn those axles, just my $0.02. I would look into just using the whole drivetrain out of the samy, they actual work out about perfect because of the short wheelbase
    Re: Jedi Rock Buggy
    Oct 2006
    Pittsburgh, PA
    A Baja SAE team built a 10hp rock crawler for the 2007 competition.
    Here is their website:
    OpieBennett --::-- CSUS Mini Baja
    The links to other forums document most of the build and parts used.
    Here is a video of it in action:
    YouTube - UA Baja Footage of CSUS Rock Crawl
    It was the only buggy to complete the rock crawl course.
    While that buggy is a good example of what you are looking to build, it did not do very well as a Baja SAE car since it was too slow and had very poor handling to be a race vehicle. But for 6-10 year old kids, a similar vehicle would work quite well.
    Re: Jedi Rock Buggy
    Quote Originally Posted by minibajaman View Post
    That's funny. Opie is an acquaintence of mine and I have followed his build on several boards. He is helping me with technical stuff as well.
    Re: Jedi Rock Buggy
    Sep 2005
    Pacific Northwest
    That buggy was GREAT. They were the only ones to best ours in the rock crawl. Good thing they got their run in before the tree limb fell
    Re: Jedi Rock Buggy
    Did some quick sketches.
    61" wheel base
    96" overall length
    66" overall width
    60" overall height
    Still have a bunch to move around. I'm going leaves because I have them for free. Just going to use 2 full length ones. The rest will come out of the pack.
    Re: Jedi Rock Buggy
    Haven't updated in a while. The frame is built. Axles were disassmbled, the gears welded, and reassmbled. Picked up a tranny from a Polaris 500. The motor I got is a Kohler 20hp running on propane. CVT should be here this week. Hope to have the axles and drivetrain mounted this weekend. I've been making brackets and such for that purpose. I'll post pics after this weekend.
    Steering will be full hydro. Using a Toyota MR2 12v power steering pump and a single ended, double acting ram.
    Re: Jedi Rock Buggy
    Feb 2009
    Baton Rouge area
    i look forward to seeing the pics....
  1. My new buggy/ kit car project
    Last Post: 01-07-2009, 06:22 AM
  2. Mini Rock Buggy
    By DrakAttack in forum MiniBuggy.net Lounge!
    Last Post: 07-31-2008, 09:06 PM
  3. Input Wanted for my next build.
  4. Short Race Car?
    Last Post: 06-30-2007, 04:40 PM
