Old 09-21-2008, 02:56 AM   #1 (permalink)
Default Waitin' on parts
Well, The Rage Pilot is on hold untill I can get some parts in. Sooo, I decited to do some fab work and testing on the FL800.
I did some clutch work trying to get more belt life. What I found is with the engine mounted in rubber and the gas tank mounted in rubber, I was getting too much flex out of the mag side engine mounts and the clutches getting out of alignment under load. I do have a torque brace on the PTO side but the mag side is flexing forward. I'm trying to find a good place to put a torque brace infront on the mag side. Some of my Sno-go guys think I should use an aluminum rod with heim joints, I'm not sold yet on that idea, think there's too much vibration in that setup and I'll break something..
So what I've done is redrill the motor mounts and shift the motor out of aligment by an 1/8" (measured at the outside of the clutch) so when under load, shifted out with belt speed at it's fastest it will pull it in. I chose 1/8" by the un-scientific method of taking off the secondary clutch shims so the clutch will float, putting on a small piece of hose on either side of the clutch and allow it to push the hose one way or the other. It worked but what a mess! I found out the RPM trans does not like a floating clutch. But with the clutch free to move on the input shaft I could see a noticable increase in top speed, and hp to the ground. Short vid Top speed right at 70 mph.
Also I'm still fighting the Axle grinding problem, so I had the end of the axle machined and tapped so I can attach some UHMW to the end of it. Keeping my fingers crossed.
While I had the engine out, I also made some mods to the frame, Made it so both clutches come off with out engine removal, clearanced some tight spots.
Wayne
waitin-parts-cv-problem-010.jpg  waitin-parts-cv-problem-007.jpg  waitin-parts-cv-problem-006.jpg  waitin-parts-cv-problem-002.jpg
Old 09-21-2008, 05:25 AM   #2 (permalink)
Default Re: Waitin' on parts
Simply awesome Wayne!
It's raining,blowing and just crap weather here today Downunder,those vids are just the thing to warm me up again Mate.
bazz is offline   Reply With Quote
Old 09-21-2008, 07:23 AM   #3 (permalink)
I miss that sound with my big muffler on now I do not miss the headache it gave me though
Old 09-24-2008, 05:01 AM   #4 (permalink)
Haysuse Wayne, Thats some serious yeeHa,, I was thinkin of lettin my second float, Bad idea I guess. Is it makin a mess of the keyway shaft itself? or the rubber flyin?
Old 09-24-2008, 08:15 PM   #5 (permalink)
How much are you letting it float, my drack floats about 1/4 or just under, and seems fine...I lubed the shaft up with some anti-seize prior to installing it tho...
Old 09-25-2008, 01:29 AM   #6 (permalink)
Bugpac,
The RPM trans has a seal ring on the input shaft that pushes on a interanl O-ring that seals the trans. When I took off the clutch alignment spacers that seal ring came out and slung oil all over everything, made a real mess with the sand and all.
On my eariler Polaris sno-goes they had a 1/4 inch float from the factory, and your right just kept the shaft anti-sezied/greased well.
This weekend I hope to have the Pilot together and do some more testing.
Wayne
Old 09-25-2008, 04:17 AM   #7 (permalink)
Originally Posted by Akpilot View Post
Bugpac,
Wayne
Ah that makes sense now...I have a press in seal...
New ProtoDie drive train ,wheel hubs, steering knuckles and parts ProtoDie For Sale 11 12-19-2008 04:47 AM
Rorty R11 and R16 Laser cut parts Kludge For Sale 14 03-13-2008 04:31 AM
Barracuda laser cut parts Mike For Sale 0 07-21-2007 07:27 PM
Brand New High End Parts For SALE- CHEEP bigal1cars For Sale 9 01-21-2007 03:42 AM
A good link for some good used motorcycle parts gsxr600 MiniBuggy.net Lounge! 0 01-17-2007 07:29 PM
