Old 07-30-2008, 04:21 AM   #1 (permalink)
kawonda's Avatar
Default FL350 front shocks
Has anyone ever installed longer shocks on the stock fl350 front end? There is 5" of actual wheel travel. There are also bump and droop stops built in, to prevent the tie rods from hitting the frame. The stock shocks just don't cut it. I was thinking along the line of quad front shocks. Any comments or advice will be appreciated. Thanks, Rob
kawonda is offline   Reply With Quote
Old 07-30-2008, 04:27 AM   #2 (permalink)
s__i__v's Avatar
Default Re: FL350 front shocks
i've heard that works shocks are "the best" for odysseys and pilots
Odyssey Salvage
s__i__v is offline   Reply With Quote
Old 07-30-2008, 04:33 AM   #3 (permalink)
greasemnky's Avatar
buy some works, livewire and a few guys sell them. OR do yourself a favor, take a grinder, and a welder, and install youself some quad a-arms in the front. Will make a world of diffrence. 400ex arms work well.
greasemnky is offline   Reply With Quote
Old 07-30-2008, 04:39 AM   #4 (permalink)
kawonda's Avatar
Works shocks don't give you a noticible difference. And I don't want to spend the time right now for a-arms. I am willing to weld a new upper shock mount to accommodate a longer shock. Just wanted to know if anyone has done this, and if so, what shocks did they use.
Old 07-30-2008, 06:45 AM   #5 (permalink)
greasemnky's Avatar
its not the shock, its the j arm. Its just not ment to give a really smooth ride. It was cheap to build, and fairly heavy duty. I've seen guys do high mounts and fox airs in the rear. But anyone who goes through that trouble in the front, usually gets rid of the a-arm first.
Try it, maybe run some DS650 shocks or something like that, and see how they ride.
Old 07-30-2008, 06:50 AM   #6 (permalink)
s__i__v's Avatar
*scratches chin*
the DS up front... but what aboot for the rear on a dirt budget?
Old 07-30-2008, 01:07 PM   #7 (permalink)
LiveWire's Avatar
Works shocks in the front do give you a noticeable difference, just not as great as the improvement in the rear. The Works shocks give you as much travel in both the front and rear as you can without making other modifications.
This is and old video before I had A-arms where I had Works shocks front and rear: http://www.aftershockmotorsports.com...clean_jump.wmv
FL350 front disc brake question kawonda The Pilot & Odyssey Forum 2 08-23-2008 07:06 AM
fl350 front suspension and misc Q's s__i__v The Pilot & Odyssey Forum 10 07-27-2008 03:47 AM
modified fl350 FOR SALE in SO CAL xmotorcr For Sale 3 05-03-2008 07:54 AM
Race Ready Honda Odyssey FL350 ((Sold)) EEERacer For Sale 3 11-01-2007 08:26 PM
front a arm rake Boyd Suspension - Wheels & Tires 22 07-30-2006 09:35 PM
