You need to find out what the max wattage output of the Oddy's engine is and then work backwards from there. You don't want to run over 80 - 85% of total output, as the system needs to be able to run the CDI and the charging system. Contact Livewire - he'll know.
#4 (permalink) |
For some reason even though the lights have 25 watt bulbs in them, I think the service manual says the lights are 35 watts. There was a Hondaline light kit that added two more lights on the front bumper. So it would seem even Honda used 140 watts total. Even if really only 25, that is 100 total. I have used two 55s without issue.
#7 (permalink) |
Tada! The answer we needed. Limit yourself to about 135 watts of use and you shouldn't have any issues.
BDK's hit it on the head - run one good HID and you'll be fine. But remember, just because a 35 watt HID uses 35 watts of power at the bulb, that doesn't mean it uses 35 watts at the power source. Check the draw needed for supplying the HID lights.
#10 (permalink) |
I just got a set of the 4" HID's from Checker Auto. They have been talked about alot on some of the Dune boards and have had real good review's. You can't beat the price. $230 / pair shipped.
They are way better than the stockers. |
| FL350 clutch/belt questions | 1stwarrior95 | The Pilot & Odyssey Forum | 28 | 09-02-2008 02:37 AM |
| FL350 front disc brake question | kawonda | The Pilot & Odyssey Forum | 2 | 08-23-2008 07:06 AM |
| cv question | Stomper | Driveline | 32 | 07-17-2008 11:38 PM |
| Snowmobile Engine\Exhaust\Chaincase Question | cuda | Motor - Engine | 2 | 03-16-2008 01:50 AM |
| General Rules and Information for our Database | K-fab | Class Development | 12 | 09-20-2007 02:27 AM |
