Old 10-20-2008, 01:06 AM   #11 (permalink)
Admin
Gene's Avatar
Default Re: FL350 Headlight Question
I bought the same lights at Shucks (look them up on the web, same as checker) and the lights cost 99 each. On line is higher.
Old 10-20-2008, 06:24 PM   #12 (permalink)
plkracer's Avatar
At any rpm I doubt it makes more than 160. It is probably limited by the regulator too.
It finally moves!
Old 10-21-2008, 01:48 PM   #13 (permalink)
Definately get yourself some HID's.
I am running a pair of them on my Racing Pilot Downunder,and at the night races they are FAR superior to the QH's.More than double the lighting power/performance and only using bout a 1/3 the wattage(35W).I have had NO probs so far after bout 1 year of racing/rec driving.They also have the poly protective covers to save the lens's.Will not overtax your elect system/bat.Highly recomend them,even put some on the front of my Nissan 4by!...Baz
bazz is offline   Reply With Quote
Old 10-27-2008, 11:50 PM   #14 (permalink)
enemy's Avatar
Can you run an HID without a battery though? I was under the impression from Trail Tech that on a stator only system, at low rpm's the output is not enough to keep the ballast lighting the gasses. Something you might wanna look into before plucking down the cash.. Or do some Pilots have a battery??
D&S Rail, Hayabusa Powered, Velocity Stage 1 @ 7psi, Custom up pipe and plenum, Jeffco FNR , some missing seat foam. ..oh... [removes underwear].....there it is..
enemy is offline   Reply With Quote
Old 10-28-2008, 12:59 AM   #15 (permalink)
plkracer's Avatar
I thought pilots did since they are electric start. I think the odyssey 350's are too??
It finally moves!
Old 10-28-2008, 01:22 AM   #16 (permalink)
Stumped's Avatar
Yes both pilots and the 350 odyssey have electric start and a battery.
Stumped is offline   Reply With Quote
Old 10-28-2008, 02:19 AM   #17 (permalink)
enemy's Avatar
Hell yea! your good to go then!
FL350 clutch/belt questions 1stwarrior95 The Pilot & Odyssey Forum 28 09-02-2008 02:37 AM
FL350 front disc brake question kawonda The Pilot & Odyssey Forum 2 08-23-2008 07:06 AM
cv question Stomper Driveline 32 07-17-2008 11:38 PM
Snowmobile Engine\Exhaust\Chaincase Question cuda Motor - Engine 2 03-16-2008 01:50 AM
General Rules and Information for our Database K-fab Class Development 12 09-20-2007 02:27 AM
