Old 07-18-2008, 01:55 AM   #1 (permalink)
kawonda's Avatar
Default FL350 front disc brake question
Does anyone know if there are any quad spindles that bolt to FL350 J-arms. I want to convert to disc brakes. Thanks, Rob
kawonda is offline   Reply With Quote
Old 07-18-2008, 01:03 PM   #2 (permalink)
Default Re: FL350 front disc brake question
Can I ask why? Put some stainless brake lines on it, and it will increase your brakeing power tremendously....You will not find any disk set up that gives you as much pad/disc surface contact than the drums do...They will wear out much faster IMO...Properly adjusted with stainless lines,the drums will lock up on pavement.....
Hoodlum
Hoodlum is offline   Reply With Quote
Old 08-23-2008, 07:06 AM   #3 (permalink)
I've got disc brakes on the front of my 350. I used 87/88 TRX250r hubs on the stock oddy spindles and built my own brackets for the calipers. I used TRX450r dual piston calipers.
Why? My biggest reason was converting to a more readily available front wheel bolt pattern, and I like to build things...LOL
I'm still in the engine rebuilding process though, so I can't tell ya how, (or even if), they're going to work.
I've got pics.
1stwarrior95 is offline   Reply With Quote
FL 350 front disc brakes kawonda For Sale 2 07-18-2008 07:23 PM
Newb to the board! 350 Oddy front disc project! 1stwarrior95 The Pilot & Odyssey Forum 13 04-24-2008 04:55 PM
General Rules and Information for our Database K-fab Class Development 12 09-20-2007 02:27 AM
Disc brake wrap ??? buggito MiniBuggy.net Lounge! 2 10-15-2006 06:31 AM
Front brake set up dilema buggito Suspension - Wheels & Tires 6 05-09-2006 02:52 AM
