Old 07-06-2008, 05:15 AM   #1 (permalink)
Default Phazer transplant begins
Phazer transplant project
PilotHawK is offline   Reply With Quote
Old 07-06-2008, 05:36 AM   #2 (permalink)
Bullnerd's Avatar
Default Re: Phazer transplant begins
YOOUUUUUU - D!@k!!(in the voice of Jeff Spicoli)
Ok ,i got that of my chest.(because you bought the engine i want)
Good luck,it should be a sweet ride when its done.
Old 07-06-2008, 08:28 AM   #3 (permalink)
How does the output shaft rpm on the yamaha engine compare to the pilot engine, (has the yam engine got reduction from crank to output shaft?)Will you end up with higher top speed or better acceleration or both?
Should make a fast but civilised pilot, Good luck.
Old 07-06-2008, 07:28 PM   #4 (permalink)
The output shaft on the phazer is via gear reduction. I am not sure of the final ratio, but it is designed for a snowmobile and a CVT system. I am not sure of the diameters of the yamaha clutches to know for sure how the diameter of the pilot CVT will compare. I do believe that the phazer driven is around 10-3/4" in diameter though and the pilot driven is just under 9" in diameter. I have a new input shaft for the pilot so I can change to an adjustable driven, but I won't be able to put a driven in that is much larger than 9-1/2" unless I shift the driven clutch further left in the machine.
A stock pilot spins about 7000 rpm, and from reading about K-fab's conversion, a phazer will spin the output shaft upwards of 8000 rpm. So if I go with the pilot stock driven, and a powerbloc for the pilot on the phazer engine, I will definitely gain top-end. With the extra HP and torque of the engine I seriously doubt the stock pilot driven will be able the handle the job. I am currently searching for a driven clutch that is the correct size and is tunable.
Old 07-06-2008, 08:51 PM   #5 (permalink)
the 600 pilot is running a 10" driven, it did move out away from the trans at the same time, wich was better for the twin anyway....Keep at it, youll have it done in no time...
Old 07-07-2008, 04:09 AM   #6 (permalink)
Jay1823's Avatar
Unless you have a stubborn tranny that sucks balls, oh wait thats my Pilot tranny.
Jay1823 is offline   Reply With Quote
Old 07-08-2008, 02:03 AM   #7 (permalink)
Well I got the rest of the pilot engine out today. I really wish I would have power washed this thing before I started! The parts are boxed up and are getting shipped to the new owner tomorrow.
Once I get the thing cleaned up a little more I'll post pictures.
I also think that while I have it apart I will install a LT front and rear suspension. After everything has found a home in the chassis, I will strip the frame back down and have it powdercoated. Probably back to red, but I'm seriously considering a dark metallic gray.
I have also ordered another input shaft from ATVnut with a 1" keyed shaft. I bought one from RPM already, but it is just too short, and I'd rather have a one piece shaft instead of cobbling an input shaft together. Since I am going to have to shift the driven clutch to the left about 3-4" in order to accommodate the engine placement I should be able to go with at least a 10" clutch if not a 10-3/4. If I can go all the way to 10-3/4 then I'll install a team rapid reaction clutch. If not I'll go with a 10" arctic cat roller driven.
Old 07-08-2008, 04:06 AM   #8 (permalink)
I think the atvnut built 600 has a 10.75 clutch, not 100% sure tho....Of course you are using a different motor as well, but im pretty sure it clears the rear frame...
Old 09-12-2008, 03:16 AM   #9 (permalink)
I've finally started to get some parts in (Thanks odypilots!) and now I might finally be able to start making some progress on the conversion. I snapped a few pictures of the new driven clutch I'll be using, and the iNput shaft as well. I had the iNput shaft made extra long so I could cut off what I didn't need instead of wishing I'd have had it made a 1/4" longer.
phazer-transplant-begins-p9110012.jpg  phazer-transplant-begins-p9110013.jpg  phazer-transplant-begins-p9110014.jpg  phazer-transplant-begins-p9110016.jpg  phazer-transplant-begins-p9110017.jpg
Old 09-12-2008, 03:25 AM   #10 (permalink)
jumpin jellybean's Avatar
Good thinking looking good the phazer was a great engine
Tags
conversion, phazer, pilot, snowmobile, transplant
Yamaha phazer engine on e-bay. Bullnerd MiniBuggy.net Lounge! 5 06-10-2008 10:58 PM
2007 Yamaha Phazer 500 engine on e-bay! Bullnerd MiniBuggy.net Lounge! 16 02-24-2008 04:08 PM
Yamaha Phazer E-start 485cc fan cooled 56+hp engine package opsled For Sale 10 02-21-2008 03:58 AM
It's Hogmanay the count down begins Hambone MiniBuggy.net Lounge! 0 12-31-2007 09:39 AM
Super-Kart Back from Powdercoat, Now the Work Begins FRANCO MiniBuggy.net Lounge! 45 02-14-2007 07:59 PM
