#11 (permalink) | |
![]() That sux because I cant tig plastic very well. I would flush by puting a valve before the fuel pump to run race gas through untill it starts to sputter so you know that its loading up from all the fuel. |
#12 (permalink) | |
P.S I usally dont stray to far from the "base". |
#14 (permalink) |
A smaller motor can be made to run like all heck but you need to work on it a lot more to keep it alive. I understand having a lot of money in something but sit down and figure how much more to build it higher then frequent piston changes and cranks and bearings etc.
I myself (as have most) have spent a lot of money trying to prove a point somewhere along the way. A 500 Polaris is no slouch but its not like its major fast either. Each way has its highs and lows. Get a piece of paper and figure out the realistic cost and then figure out which would be the most fun for you as as long as you are having fun you will be happy with it. Some like wrenching and some only like riding and some like both. Bill |
#15 (permalink) |
Here is one possible setup:
Add a poly tank and leave the stock tank. Stock tank is filled with regular gas mixed with an oil compatible with the alcohol. The poly tank is filled with the alchohol and also mized with oil, possible different ratios. Install a Dial-A-Jets into a 39 PWK. The Dial-A-Jets is fed off the alcohol. Drop the main jet size in the carb and the needle down. At idle, the Dial-A-Jet will not add anything. When You get on it hard where it would detonate and where it makes more heat, it will add the alcohol. When you go back to idle, the alcohol will automatically be flushed out of the engine. I have a motor nearly done that is 68cc over standard. I can go up to 101cc over with basically the same setup. I started on the small side to work through any issues. I then have plans for a 115cc big bore setup that needs more elaborate case work. All this is on that back burner though with the purchase of the tooling for the Formula Cross and Extreme. |
#16 (permalink) | |
#17 (permalink) | |
68cc over standard - Is that with the original 80mm piston (making 410cc) or with the recalled 78.5mm. (making 397cc) |
#18 (permalink) |
If the poly tank is higher than the carb, then you need a float bowl for the Dial-A-Jet. You use one off a carb mounted to a flat plate with the inlet in the plate. The outlet is also in the plate, but has to have a tube going down to the bottom.
If the tank is below the carb, you need a fuel pump anyway. The fuel is pumped into a canister with an overflow at the level you want the fuel. The pump fills the canister and the excess drains back keeping the level steady. I just looked up the website for pictures of the Dial-A-Jet and I guess you can buy the remote float bowl: Thunder Products - Performance carburetor and clutching for snowmobiles, motorcycles and ATVs. |
#20 (permalink) |
A water cooled head and rad costs less than some of the mods you have listed. I have seen used heads go on ebay for around 150 and used rads for 10 bucks. With the overheating issues that a stock fl350 has, I would consider water cooling to be a must before other mods are done. Running Alcohol sounds fun, but I would start with the basics, just my 2 cents.
| FL350 clutch/belt questions | 1stwarrior95 | The Pilot & Odyssey Forum | 28 | 09-02-2008 02:37 AM |
| 1985 FL350 with Aftershock A-arm kit | AtvNut | For Sale | 14 | 05-04-2008 11:19 AM |
| modified fl350 FOR SALE in SO CAL | xmotorcr | For Sale | 3 | 05-03-2008 07:54 AM |
| Running hare scramble,s for minis | LEE1969GB | MiniBuggy.net Lounge! | 16 | 12-16-2007 04:20 PM |
| General Rules and Information for our Database | K-fab | Class Development | 12 | 09-20-2007 02:27 AM |
