#11 (permalink) |
ya i have that wire on mine!
its green though and it conncts from the pull start to the frame. if i had my camera i would take pics for ya.
#12 (permalink) |
so it goes from one of the bolts that hold the pull start over to the frame? im thinking since this is so close to the stator this might be my problem if the stator dont have enough ground it could be missing bad enough to seem like it is bogging i will make a ground wire and put it on and try that hopefully that fixes it i will let you all know either way
#15 (permalink) |
well top right if your looking at it!
sorry about that ya it could have been a ground problem but tell us your results! ![]()
#16 (permalink) |
i got the ground wire hooked up but i didnt get the carb put back on before dark so ill stick the carb on tomorrow and give it a try if that dont fix it im gonna jet it fatter and if that dont work im going to hook the stock tank and fuel pump back up and try that at least i have a game plan right hahahah
#19 (permalink) |
What happened to your game plan???
Stock tank and pump Make sure you have a filter... AND you sure should be nice to us guy's cause we know a dirty little secret we could blackmail you with LOL Good Luck, and did it ever occure to you the 2 stroke smoke brought on the asthma??? Just kidding gald she is feeling better!!! |
#20 (permalink) |
thanks turbo she is doing fine im gonna try the stock tank tomorrow and the fuel pump do you really think that might be my problem? im just looking for some kind of hope. i will let you giys know tomorrow. this carb might set up for a pump and only a pump gravity feed might not work for it
