Old 10-23-2009, 11:31 PM   #1 (permalink)
Default fl350 throttle cable problem
I bought a new throttle cable for my 350. It worked fine at first but after I adjusted the mixture, the throttle wounldn't completely retract back. When I unscrew the top off the carb it retracts like it is suppose to. Bad spring in the carb? Any help GREATLY APPRECIATED.
ataboc is offline   Reply With Quote
Old 10-24-2009, 12:07 AM   #2 (permalink)
nutz4sand's Avatar
Default Re: fl350 throttle cable problem
Welcome to the site.
Was the cable a factory part? Or after market? Did you lube it before installation? Is the spring in the carb damaged at all if you can tell or does it look fine?
Sand! The only gold I need!
Old 10-24-2009, 02:05 PM   #3 (permalink)
It may be that the carburetor slide (the part that dangling from the cable when you unscrew the top of the carb and pull it out) may need to be rotated as it's lowered back in. It has to be turned a certain way. If not, it can stick when used.
I race, therefore I am
odypilots is offline   Reply With Quote
Old 10-26-2009, 03:18 PM   #4 (permalink)
LiveWire's Avatar
The plastic pin that aligns the slide has been known to get worn off. The slide will then not stay rotated properly which will prevent it from closing all the way.
throttle cable lynnbg The Pilot & Odyssey Forum 2 05-09-2009 01:11 AM
throttle cable help adubaz7 Controls and electrical 3 07-07-2008 05:44 AM
Throttle Cable TxBandit Controls and electrical 11 01-26-2007 04:09 AM
snowmobile engine dgcrsn Motor - Engine 16 12-16-2006 04:42 PM
ST2 and throttle cable buggito MiniBuggy.net Lounge! 12 07-04-2006 09:39 PM
