Old 10-11-2009, 10:21 PM   #1 (permalink)
SLICK WILLY's Avatar
Default fuel tank question
can you put a fuel tank above the carb and do away with the factory fuel pump or will it not supply enough fuel to the carb being gravity fed has anyone done this thanks for any help
SLICK WILLY is offline   Reply With Quote
Old 10-12-2009, 01:35 AM   #2 (permalink)
Default Re: fuel tank question
well i mounted a fuel cell above the carb onto the frame and it does fine, its gravity fed all i have between the fuel cell and the carb is an inline fuel filter.. got rid of the stock pump and t just cause it was always a hassle and i have had no problems with this setup!
87 tecate 4
83 hoda odyssey fl250
ruthlessxbeastx is offline   Reply With Quote
Old 10-12-2009, 02:54 AM   #3 (permalink)
If it were me... and the stock tank was in good shape I would rebuild the pump. The rebuild parts can't be very much money and it's easy to do. Put new hose's on and check for vac leaks.
millbilly is offline   Reply With Quote
Old 10-12-2009, 08:12 AM   #4 (permalink)
ya if your tank is good. mine was rusted to hell i rebulit my pump and yet my ody just kept bogging down and dying. so i just finally scrapped the tank and bought a fuel cell
87 tecate 4
Fuel Cell And Fuel Delivery Question?? GR8WHITE Motor - Engine 20 01-31-2009 08:09 PM
Fuel Tank and Foam question? plkracer Motor - Engine 18 11-30-2007 04:32 PM
Doubledown and hair pulling fuel pressure puzzles amergin MiniBuggy.net Lounge! 13 11-14-2007 07:22 AM
General Rules and Information for our Database K-fab Class Development 12 09-20-2007 01:27 AM
FUEL TANK QUESTION dune Motor - Engine 6 01-26-2007 02:31 PM
