Go Back   MiniBuggy.Net: The Ultimate Off-Road Buggy Community > :::Fabrication::: > Motor - Engine
Old 10-01-2008, 05:50 PM   #1 (permalink)
Default Can't find a 630 18t sprocket for ZX14 , any help?
I have called Sprocket Specialists and a few other places. Anyone know where I can get one?
Old 10-01-2008, 06:11 PM   #2 (permalink)
bdkw1's Avatar
Default Re: Can't find a 630 18t sprocket for ZX14 , any help?
18 tooth counter shaft sproket? Isn't that a little large? Will it even fit?
Old 10-01-2008, 06:34 PM   #3 (permalink)
yoshi's Avatar
Advanced Precision Products (Randy).......541-347-7262 / 888-347-7262
tell him Yoshi sent ya..
www.sinistersandsports.com
Old 10-01-2008, 07:04 PM   #4 (permalink)
busasandrail's Avatar
Exactly where I was going to say.....APP does quality work at a great price.
Nothing is impossible---it just costs more money.
EL TORO sand car w/(soon to be) TURBO 1397 Busa / Subaru STI diff. / cutting brakes
www.eltorosandcars.com
Old 10-01-2008, 07:12 PM   #5 (permalink)
Well I know a 18t 530 fits but I don't know if a 18t 630 fits. Stock is 17t 530. I am going to be running 1:1 on the sprockets so I am gonna stick in the biggest one that will fit to try to cut down on the heat. I also have the chain length as long as possible in the design. I know some people here are using 630 stuff on busa powered cars. The thing is, Krause has a 530 chain that is higher tensile strength than any 630 chain I can find. I have read here that there is still stretching and chasing the tensioner issues with even that chain and seemed to be cured with a lower tensile 630 chain? I would really like to know how...
Old 10-01-2008, 10:20 PM   #6 (permalink)
If your going to convert from 530 to 630 you need to use the o.d. of the sprockets not the teeth count.....
And I am one of the guys who converted from a 530 to 630. I use a RK SO630 (10600 psi strength I think) chain on mine with out a tensioner. I basically set it up so the chain is pre-tensioned and adjusted as it sits in the frame. And I can say now after a full year of use the chain has not stretched more then a mm or 2. And IMO could still run another season on the chain which I probably will, just to see how long it will run.
Old 10-01-2008, 10:24 PM   #7 (permalink)
Also are you using a o-ring/x-ring chain.....I know for a fact that the NON o-ring/x-ring chains DO NOT last in the sand. That goes for both the 530 and 630 chains.
Old 10-01-2008, 10:46 PM   #8 (permalink)
I am not using anything yet. I am just getting started on the build this weekend. Just trying to plan it out in advance.
So a krause chain has a TS of 15,000. A o-ring 630 is 11,000. What makes it better? or is it better? Has anyone had failure on the krause chains here?
Old 10-01-2008, 10:59 PM   #9 (permalink)
plkracer's Avatar
Bug has. He didn;t have very good luck with his first car. I'm using an r/k 530 on mine and it barely stretched after an hour of running. Need to move the tensioner back 1/8 inch.
It finally moves!
Old 10-01-2008, 11:09 PM   #10 (permalink)
plkracer's Avatar
Forgot to mention, but a smaller sprocket also puts more tension on the chain. Say you have 100 ft lbs at the outut shaft in gear X. If you use a 1 foot diameter sprocket, unrealistic, but just for this purpose, you have 100 lbs of pull on the chain. Now say you get a 3 inch sprocket. This tension jumps up to 400 lbs. Bigger sprockets means you can, theoretically, use a weaker chain, and vise versa.
It finally moves!
RPM sprocket mounting SeufererMotorsports Driveline 10 10-25-2007 04:14 AM
drive sprocket forward yellowbeard Driveline 22 12-25-2006 03:36 PM
Sprocket & Chain refresher course BoneDuner Driveline 5 12-06-2006 10:16 PM
Sprocket sizes... yoshi MiniBuggy.net Lounge! 4 09-23-2006 02:41 AM
Sprocket diameter buildstoys Driveline 10 09-09-2006 10:20 PM
