Go Back   MiniBuggy.Net: The Ultimate Off-Road Buggy Community > :::Fabrication::: > Motor - Engine
Old 10-01-2008, 11:28 PM   #11 (permalink)
busasandrail's Avatar
Default Re: Can't find a 630 18t sprocket for ZX14 , any help?
Originally Posted by standfast View Post
I am not using anything yet. I am just getting started on the build this weekend. Just trying to plan it out in advance.
So a krause chain has a TS of 15,000. A o-ring 630 is 11,000. What makes it better? or is it better? Has anyone had failure on the krause chains here?
I cant speak for the krause chain.
But I can tell you what I have run and have seen run in the sand cars
zvx 530---good chain, does stretch
zzz 530---better then the zvx, less stretch and better longevity, good choice for busa rails, w/ a good adjustment system
530 drag chain---do not use in the sand. gets super hot and stretch/wears out fast.
630 drag chain---same as 530 just stronger and heavier
SO630---good chain, about zero stretch, lasted a full season and still good. I don't have a tensioner system on my car and havent adjusted my chain since installed back in March.
Nothing is impossible---it just costs more money.
EL TORO sand car w/(soon to be) TURBO 1397 Busa / Subaru STI diff. / cutting brakes
www.eltorosandcars.com
Old 10-02-2008, 04:13 AM   #12 (permalink)
Can someone tell me if stretch is directly relative to tensile strength or is there more to it?
I am assuming based on your results that there is more to it because the zzz530 has a TS of 11,000 and the SO630 has 10,600 but doesn't seem to have any stretch. What gives?
standfast is online now   Reply With Quote
Old 10-02-2008, 04:51 AM   #13 (permalink)
bdkw1's Avatar
Stretch is related to the bushing wear in the roller, The 630's have larger bushings and don't wear as fast even though they have a lower ultimate strength.
Old 10-02-2008, 05:44 AM   #14 (permalink)
Gotcha, so it sounds like 630 is the way to go.
Old 10-03-2008, 12:09 AM   #15 (permalink)
405dentech's Avatar
If your still looking for sprockets, you might give SIDEWINDER a call 1-630-513-1000. I talked to them today and they even had a 13tooth 530 front sprocket for my 600 in stock. Expensive though almost $70 a sprocket.
405dentech is offline   Reply With Quote
Old 10-09-2008, 01:55 PM   #16 (permalink)
yoshi's Avatar
Tell me about the SO630, what brand and how much?
That same sprocket is about $25 through advanced precision products.....
www.sinistersandsports.com
Old 10-09-2008, 03:50 PM   #17 (permalink)
Heres the page for the RK SO630 chain...
New Page 1
They also run a few bucks cheaper then the zzz530 in the same length.
Edit: I always use the clip style connecting link on mine.
Old 10-09-2008, 09:06 PM   #18 (permalink)
enemy's Avatar
New Page 1
That's the same chain I am running, hasn't worn at all during the test beatings.. I'm also using a clip type masterlink....that rivet style sucks IMO A 16 tooth (in a 630 size) on a Busa is gunna be about the biggest that can fit under stock cover I would think, mines a tight fit. Might be the same close fit on a 14, maybe why you're not coming up with one..
D&S Rail, Hayabusa Powered, Velocity Stage 1 @ 7psi, Custom up pipe and plenum, Jeffco FNR , some missing seat foam. ..oh... [removes underwear].....there it is..
enemy is offline   Reply With Quote
Old 10-09-2008, 09:49 PM   #19 (permalink)
Makes sense. Fitment probably is the issue.
RPM sprocket mounting SeufererMotorsports Driveline 10 10-25-2007 04:14 AM
drive sprocket forward yellowbeard Driveline 22 12-25-2006 03:36 PM
Sprocket & Chain refresher course BoneDuner Driveline 5 12-06-2006 10:16 PM
Sprocket sizes... yoshi MiniBuggy.net Lounge! 4 09-23-2006 02:41 AM
Sprocket diameter buildstoys Driveline 10 09-09-2006 10:20 PM
