Hello all
It appears that I have finally licked the drive chain problem so I'm lookin for more power so I can start shredding parts again. What I want to know is the optimum turbo peices that will be RELIABLE I will buy the parts and build my own system cause I don't like the 3k price tag on a complete kit. Info on the following parts please Turbo with wheel specs Waste gate size BOV SS header links Thanks in advance for any info |
#3 (permalink) | |
Garrett GT25R ,internal wastegate,good to approx 350+ hp. Works very well at 10-15#'s boost. Tial of equivalent. FWIW I would highly suggest you spend a few hours at the SuzukiHayabusa.Org website.There are some VERY smart guys there that are nicer(and much smarter) than me to ask questions of.LOL!!! It will be very worth the time spent. Just go to the forums and research till your eyes bleed.
#4 (permalink) |
Put an intercooler on it and you can do 250-300hp on pump gas too!!!! Use a powercommander along with an FMU and you won't need to upgrade injectors or do piggy backs either. Spend a few bucks at a good dyno and you're set. Should be very reliable. I did my own t'bo system and instead of the dyno
(which is best) I used on board data logging of afr/rpm/throttle position /egt to tune. I'm a DIY kind of guy.BTW,Arrowhead it would be nice if we could get back on good terms! I'm really not the asshole you think. ![]()
#5 (permalink) |
want to get really technical, forget about the power commander and get rid off the gixxer computer all together, add a mega squirt controller and a wide band o2 sensor....With the mega squirt system you can calibrate any sensor etc, regardless make model or yr....
http://www.msefi.com/index.php Some very interesting things going on with this unit... Last edited by Bugpac; 08-19-2008 at 02:15 AM. |
#7 (permalink) | |
#10 (permalink) |
wow I still need to read more on all this stuff have much to learn at least I can lighten the mood sorry to hijack arrowhead is the busa engine capable of hitting 20# of boost with out extensive mods thanks and now back to our reagularly scheduled program![]() |
| Las Vegas Turbo Hayabusa | jxrusso | Show off your toys in here! | 26 | 07-08-2008 08:00 PM |
| Which Spark Plugs do you run in your Turbo Hayabusa ? | DuneMe | Motor - Engine | 1 | 06-14-2008 02:44 AM |
| Ridge Runner Turbo project.... | 2007BlueRR | Ridge Runner | 9 | 10-06-2007 02:18 PM |
| FEDERAL Sandrail For Sale - Hayabusa Powered - $33,950 | FEDERAL | For Sale | 53 | 08-24-2007 06:28 PM |
| Which Chain do you run? (Turbo Hayabusa 530) | DuneMe | Driveline | 20 | 02-04-2007 10:57 PM |
