Old 08-19-2008, 04:09 AM   #11 (permalink)
arrowhead's Avatar
Default Re: The Best Hayabusa Turbo Combo
No I only want 8 lbs max nothing exotic.
Don't forget my rail is less than 800 lbs and it rips just the way it is
For my chain I use Tsubaki Omega 630 O ring with hardened 16t drive and 18t driven with PJ1 oring lube. I am installing a 4" bilge blower to cool the chain before I head south for the winter but this past weekend in Oregon it barely gets warm chasing my buddies 800hp Tatum for an hour
Old 08-19-2008, 05:26 AM   #12 (permalink)
Welcome back. What HP do you think the Honda transmission will take? I'm still very intrigued by that setup.
Old 08-19-2008, 05:46 AM   #13 (permalink)
arrowhead's Avatar
I just posted some more pics in my welcome thread.
The 84+ have a bigger(stronger) trans and I'm sure they will handle any bike motor they are very well built no bushings all Timken needle rollers etc.
Old 08-19-2008, 06:04 AM   #14 (permalink)
bdkw1's Avatar
Originally Posted by Bugpac View Post
want to get really technical, forget about the power commander and get rid off the gixxer computer all together, add a mega squirt controller and a wide band o2 sensor.
That's great if you have a dyno in your garage and a lot of time. Having done an aftermarket computer swap on My Bronco, it's not something I would be looking forward to agian.
Old 08-19-2008, 06:20 AM   #15 (permalink)
trojan's Avatar
With a wide-band fitted and closed loop enabled, you don't need a dyno, it auto-tunes
trojan is offline   Reply With Quote
Old 08-19-2008, 07:21 AM   #16 (permalink)
bdkw1's Avatar
So did the system I had...... Not. Even the best systems still need tweaking in the beginning. Their are so many variables with timing and mixture, dyno time is the only way to sort it out. On a normally aspirated motor you can get away with close enough, on a turbo not so much.
Old 08-19-2008, 07:55 AM   #17 (permalink)
trojan's Avatar
I'm curious, which system was that?
From a computer perspective, a dyno is used to compensate for an ECU that guesses rater than responds
Old 08-19-2008, 08:01 AM   #18 (permalink)
arrowhead's Avatar
Don't forget what my question was guys
Old 08-19-2008, 10:59 AM   #19 (permalink)
exactly!!
Old 08-19-2008, 12:57 PM   #20 (permalink)
masterfabr's Avatar
Those that have not done always seem to know more than those that have.
Las Vegas Turbo Hayabusa jxrusso Show off your toys in here! 26 07-08-2008 08:00 PM
Which Spark Plugs do you run in your Turbo Hayabusa ? DuneMe Motor - Engine 1 06-14-2008 02:44 AM
Ridge Runner Turbo project.... 2007BlueRR Ridge Runner 9 10-06-2007 02:18 PM
FEDERAL Sandrail For Sale - Hayabusa Powered - $33,950 FEDERAL For Sale 53 08-24-2007 06:28 PM
