#11 (permalink) |
I have always felt that one or two LARGE truck filters stacked on each other AROUND the filters on the carb would help immensly in the fact they they would pre-filter the air and be easy to change and not restrick power enough to be a factor for playing/fun running.
Tractors run in some horrible conditions and they need to protect those $$$$ motors so they have airfilters that use centrifugal force to help purge out the bigger heavier stuff and lessens even the lighter. I know Chenowth used one of these filters on at least one of thier SV16 rails. I saw it in Sandsports then met the owner at Glamis once. Some of these tractor filters are not that huge in size but still have a large filter area. The units use the centrifugal trick and are supposed to make filters stay a lot cleaner a lot longer. Might be worth a look if you hate air filter maint. Get it chromed if pretty is an issue for you. They are not to "in style" with most of todays buggies. But maybe they could be doctored up to look like something else. Bill
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs. |
#12 (permalink) |
John Deere also uses a safety filter on the inside so you can blow out the outside one, and don't have to worry about dirt entering the engine. It's a good idea, and they can get pretty dirty before you notice the engine is starved for air.
#13 (permalink) | |
They give the CFM rating on the Donaldson site, basically you figure out the max CFM your going to need, add about 25% and look for a filter that will do that at under 5" of vacuum. |
#14 (permalink) |
Yeah, that's what jd and many other tractor companies run. I've only seen the inners used in the jd's though. I know of a new holland that sucked in the outer filter and destroyed the engine. Although it was due to a clogged filter, it is possible. With the inner installed, it would have suffocated the engine, not ruined it.
| New 2 seat model from Sinister Sand Sports... | yoshi | Projects in Progress | 302 | 11-21-2008 09:37 PM |
| Shipping advise. | PilotHawK | MiniBuggy.net Lounge! | 6 | 12-12-2007 04:06 PM |
| need advise on 1998 zx7r | yossi | Motor - Engine | 0 | 06-24-2007 05:29 AM |
| Cone filter assembly??? | flyerrider | Motor - Engine | 1 | 04-15-2007 01:22 AM |
| need advise | yossi | MiniBuggy.net Lounge! | 8 | 07-14-2006 02:41 PM |
