#11 (permalink) |
If you run a stock dash and do not run the stock fuel pump your low fuel light will blink at you no biggie but it bug the s&*t out me. All you have to do is run a 100 ohms resister out of the dash to ground and the light will go out. I will get out all paper work and look it up but like I said it make me a day or two.
#12 (permalink) |
That's why there's a regulator used.A pump needs to have a higher dead head pressure than the engine requires in order to supply a stable fuel pressure to the injectors.
#14 (permalink) | |
I would run 2 fuel filters . A 100 micron before the pump and 10 micron after. |
#15 (permalink) | |
Check summit they have a summit brand high pressure and flow pump that will work for you.....#SUM-G3138
Nothing is impossible---it just costs more money. EL TORO sand car w/(soon to be) TURBO 1397 Busa / Subaru STI diff. / cutting brakes www.eltorosandcars.com |
#16 (permalink) | |
Is this the pump you are using? Looks as if I went with this exact fuel pump I wouldn't need to run a external regulator?? Summit SUM-G3138 - Summit High-Flow Electric Fuel Pumps - summitracing.com |
#18 (permalink) | |
Another member on this thread posted that his earlier model motor already had a regulator built into the OEM fuel rail. |
#19 (permalink) |
Does the fuel rail have the regulator built into it? If not then yes you'll need a regulator.
And yes that is what I'm using to run my 1397 busa motor. When I purchused it thou it was called a MSD high flow pump, right there after summit dropped the MSD and this unit appeared as its replacement. If you need a regulator then you can use a regulator from summit also #AEI-13301. This is also what I use. It works very well, just make sure you get an external fuel pressure gauge so you can make sure the fuel pressure is set right and doesn't drift on you. Edit : I lied summit does offer the pump now...#MSD 2225 either one will work for you.
#20 (permalink) | |
Get a service manual...it will tell you
| why do I have positive pressure in my fuel tank? | Damien | Motor - Engine | 12 | 02-09-2008 01:30 AM |
| Fuel Pressure Regulator? | al | Motor - Engine | 5 | 01-18-2008 02:36 AM |
| Doubledown and hair pulling fuel pressure puzzles | amergin | MiniBuggy.net Lounge! | 13 | 11-14-2007 08:22 AM |
| General Rules and Information for our Database | K-fab | Class Development | 12 | 09-20-2007 02:27 AM |
| Electric fuel pump"safety" | Bugpac | Controls and electrical | 19 | 10-13-2006 04:28 AM |
