I've resently been able to test drive the Hayabusa powered Buggy, and alltho there's more than enough power, I have got a powercommander attached, and I want to Tune it up. Whats the best way to go around this? Do i need to find a place who can Dyno tune a 'Car' via the powercommander?
I'm in Perth Western Australia. Cheers Phil |
#4 (permalink) |
My thoughts...
A dyno is used to tune by setting the AF (air fuel ratio). You can get that ratio through the use of an O2 sensor. IF you could log the O2 versus RPM while under hard acceleration, you'd pretty much have the same thing as a dyno. Check this place out: AEM - Sensors and Connectors I used one of their products sucessfully to tune my carbeurated engine. I didn't log, I just watched the ratio to see if I was lean or not. |
#5 (permalink) |
The dyno is the best way.It analyzes at a controlled rpm rate and load.I'm not saying that you can't tune it close with the use of onboard datalogging such as Innovate products logging hardware.Hell I map my t'bo busa that way.The dyno will get you closer to best though.
#7 (permalink) |
Of course you could also take the easiest way and just load up one of powercommander's ready to use maps if you're talking normally aspirated stock engine.
| hayabusa stand | 1982shawn | MiniBuggy.net Lounge! | 3 | 04-13-2008 01:56 AM |
| Polaris P-90 Clutch tuning | jonzer12 | Driveline | 0 | 02-01-2008 05:05 PM |
| FEDERAL Sandrail For Sale - Hayabusa Powered - $33,950 | FEDERAL | For Sale | 53 | 08-24-2007 06:28 PM |
| FEDERAL Turn-Key Hayabusa Powerered Long-Travel Sandrails | FEDERAL | Turnkey buggies and sand rails | 7 | 07-03-2007 05:29 PM |
| Wizard / Donahoe Racing Suspenion Tuning Seminar | KingGlamis | Suspension - Wheels & Tires | 7 | 09-21-2006 04:16 AM |
