Old 08-05-2008, 05:34 PM   #11 (permalink)
arrowhead's Avatar
Default Re: Busa oil pressure
I'm using Amsoil
Old 08-05-2008, 05:45 PM   #12 (permalink)
busasandrail's Avatar
Originally Posted by arrowhead View Post
I just don't like the low pressure at idle this is my only concern nothing else worries me
I'm using Amsoil M/C oil and filter and a stock oil cooler tilted away from the header
I also use amsoil....just set your rpms up to at least 1400 and do not let it idle for an extended period of time and you should be ok.
Also amsoils car "regular syn." motor oil is rated for motorcycle and ok for wet clutches plus it doesnt cost as much. This is what I use.....
Nothing is impossible---it just costs more money.
EL TORO sand car w/(soon to be) TURBO 1397 Busa / Subaru STI diff. / cutting brakes
www.eltorosandcars.com
Old 08-05-2008, 06:01 PM   #13 (permalink)
arrowhead's Avatar
I'm an Amsoil dealer and they have have an oil rated for crotch rockets that I use
Old 08-05-2008, 06:02 PM   #14 (permalink)
arrowhead's Avatar
I don't cut cost on oil it's the life blood of your engine
Old 08-05-2008, 07:52 PM   #15 (permalink)
So what is the difference between the two oils, motorcycle and motor oil. Both are JASO rated and designed for motorcycles? Why would you imply that the regular syn. motor oil is inferior?
Old 08-05-2008, 08:00 PM   #16 (permalink)
arrowhead's Avatar
I don't recall any implication
This particular oil was developed for high revving engines and they also have on for those lazy thumpin twins
Old 08-05-2008, 08:01 PM   #17 (permalink)
arrowhead's Avatar
It could be a sales pitch and all come from the same drum
Old 08-05-2008, 08:31 PM   #18 (permalink)
I often wondered.....But according to the bottle it's designed for it.
I have heard both sides of the story and have read many pages of threads and it seems to be a 50/50 split if motorcycle oils are really any different then a like rated motor oil. Maybe somebody on this forum knows the answer.
Old 08-05-2008, 08:35 PM   #19 (permalink)
I do know one thing the motor absolutely runs smoother and shifts way better with the amsoil.....And I will not switch back to dyno(regular) oil....EVER.
Old 08-05-2008, 08:52 PM   #20 (permalink)
masterfabr's Avatar
I use amsoil fork oil and shock oil. I haven't used the amsoil mc oil.I didn't and still don't know if it's full synthetic.Is it? I use mobil 1 gold top full syn.Never had a bit of trouble.Are the specs similar?
project busa powered side by side.... yoshi Projects in Progress 385 05-21-2008 04:49 AM
R1 vs. Busa Andy_1972 Motor - Engine 78 03-23-2008 10:58 PM
How much hp can YOU get out of a busa? P-Dog MiniBuggy.net Lounge! 20 02-24-2008 08:09 PM
Doubledown and hair pulling fuel pressure puzzles amergin MiniBuggy.net Lounge! 13 11-14-2007 08:22 AM
busa motors on craigslist butch For Sale 0 07-08-2007 05:31 PM
