Well now that i have the 440 running nicely in my mini i plan on running the hell out of it. Now since it's a fan cooled engine and i really have no experience with fan cooled engines how do i monitor the engines temp so i don't fubar it, also whats a good temp range to keep it in? Any info would be greatly appreciated. Jay
#2 (permalink) | |
you can get a thing for an rc car that shows temp, it has a probe on it i believe, Youll have better luck skinning a live cat than worrying about getting hot, ride her till she pukes... ![]() |
The r/c car sensors have a loop that wraps around the engine head. From my experience, they HATE large vibrations. I had one for my r/c car and I put it on my 400ex for the trip to sand lake. it died after a day. The electronics inside need to be held down with hot glue. Mine had vibrated a little silver cylinder to the point where the lead broke. I have an IR sensor now that I use every once in a while. The only problem with the loop is that it can be hard to mount. I think I held mine on with a zip tie around the head. Don't know if it would last too long with the heat, but I took it off after the day. You also cannot bend the loop too tight next to the sensor. You'll break the lead on the sensor.
#7 (permalink) |
You can get an adjustable fan sensor from JEGS, it will activate a light on your dash if it goes beyond the maximum specified heat rage.
Or you can buy an intelidash. |
