Go Back   MiniBuggy.Net: The Ultimate Off-Road Buggy Community > :::Fabrication::: > Motor - Engine
Old 03-16-2008, 12:24 AM   #1 (permalink)
Default Snowmobile Engine\Exhaust\Chaincase Question
I have what maybe a dumb question but here it goes.... *Due to the exhaust pipe, I'm having trouble fitting my zr 600 efi motor into my buggy. *Since I will be using a reverse chaincase could I just mount the motor backwards, so the exhaust exits to the rear of the buggy and then run in reverse to go foward?? *I haven't gotten my chaincase yet, so I'm not sure if reverse is geared differently. *If this is possible the motor would fit perfectly. *Another question since the chaincase isn't going into a sled does it matter which one I buy? *I apprieciate any light you guys could shed!
cuda is offline   Reply With Quote
Old 03-16-2008, 01:22 AM   #2 (permalink)
plkracer's Avatar
Default Re: Snowmobile Engine\Exhaust\Chaincase Question
Most chaincases won't be able to handle to load in reverse. They are usually built pretty light. Also, you want to get a box that is made to handle enough power for the engine.
It finally moves!
Old 03-16-2008, 01:50 AM   #3 (permalink)
nutz4sand's Avatar
Most chaincases are direct connected with a coupler for forward to handle full power and had a reverse idler to spin things backwards when the forward coupler disconnects. Sending a lot of power thru it in reverse for a long time and it will cause issues. I have seen my friends abuse reverse on some sleds to amazing levels but it was just back and forth to get out of a jam. Never for extended length or speed. *
If you get a different case take gear ratio into effect. I know you will have to gear it deep after the chaincase but many are very different. Bill
Some people are Humbly Grateful, while some are Grumbly Hateful.................... Which one are you ?
