Results 1 to 8 of 8
    1300 hayabusa engine weight?
    Dec 2007
    Federal Way, Wa
    I was curious to know *what is the dry/wet weight of a busa engine w/ and or w/o gearbox? Or atleast a close estimate.
    Thanks in advace.
    Re: 1300 hayabusa engine weight?
    Vendor yoshi's Avatar
    Sep 2005
    Broken Arrow Oklahoma
    Quote Originally Posted by halfrack\";p=\"55590
    Thanks in advace.
    The shipping weight on the last busa motor I got was 173 pounds with pallet, battery, airbox, headers, all electronics, and emptied of fluids...
    www.SinisterSandSports.com
    918-521-3736
    Dec 2007
    Federal Way, Wa
    How did I know you would chime in? lol
    Thanks, Im just using the weight as a reference point for a possible project.
    The gearbox is all one piece and part of the block can't remove it. *I figured about 150lbs. *1hp per pound ain't bad
    The weight of a 1300 busa engine is 220.lbs with it ready to run. It will very a few pounds depending on what you remove or add for your app.
    However if you pull it out of the bike intact with header, air box ect. It's 220.
    Welcome to MBN Sandfever!
    I shipped my engine to Heads Up Performance with throttle body and starter. Made a shipping case for it and put it on yellow frieght but it's been a long time. Seems like box and all weighed about 225. I figured the engine was about 180.
    You and Yoshi have pulled engines from complete bikes. His last Busa box seemed very light considering the components. Seems like something is missing with the weight differences.
    We weigh the engine with everything needed to run even the wiring and ecu. It's been a while sence we have weighed one. I will pull out a new one tomorrow and weigh it. JUst to be sure I am not giving out Bad info. We use digital nascar scales.
    where do you guys come across these Busas? Where can i get my hands on one?
