Old 10-27-2007, 02:36 PM   #1 (permalink)
Default 800 rotax exhaust size
The exhaust that came with my rotax 793 engine has a big outlet, sometimes called the stinger, the smallest diameter before the silencer and so has a big bore silencer (looks like a superbike race can) This is way to loud even with 2 silencers in line, does anyone have a ski doo 800 that they can measure the bore of the stinger.
With this exhaust being a 2 in to 1 I assume the whole exhaust will need to be bigger.
LEE1969GB is online now   Reply With Quote
Old 10-27-2007, 02:48 PM   #2 (permalink)
Administrator
K-fab's Avatar
Default Re: 800 rotax exhaust size
Unfortunately most two strokes are noisy. *About 30-35% of the sound is actually intake sound, much of the sound is heard through the body of the expansion chamber. *(think about it, sleds and pwc keep the power plants enclosed in a fiberglass box). *Many times stock exposed to the world expansion chambers are dual wall with a very small air space between the walls in an effort to deaden the sound.
A couple ways to help lessen the noise output of the engine are:
Air box. *This can be a pain, but can be well worth the effort too. *Open filters on the ends of the carbs are noisy, so if you can encase them somehow that will help
Wrapping the expansion chamber(s) in muffler tape helps. *It dampens a lot of the sound from the exhaust side of the engine.
On the muffler end of the system, look into one of the FMF Q pipes. *They offer many different sizes and such and I'm sure a phone call to them would direct you to a muffler that will have an inlet size that matches the output end of the expansion chamber.
[url=http://www.yellowdogracing.com/deztaz/quiet.htm:2j8qf8f8]Here's a page on how to do some of this work[/url:2j8qf8f8]
