Old 09-06-2007, 09:22 PM   #1 (permalink)
Default Building Horsepower in a B&S Engine
I'm working on a car for a Mini Baja race. All the cars use 10hp B&S Intek motors, but we can modify them as we see fit. I was wondering if anyone here had advice for building horsepower in these engines.
Thanks for the help.
and42is is offline   Reply With Quote
Old 09-06-2007, 09:54 PM   #2 (permalink)
Super Moderator
minibajaman's Avatar
Default Re: Building Horsepower in a B&S Engine
Are you working on this car for the Baja SAE competition, or just for fun? *Because if you are planning on competing with it in the Baja SAE series you cannot modify the engine at all.
Otherwise, most people on here do not use industrial engines so advice may be limited. *There aren't really any aftermarket parts available that I know of for the 10hp engine. *Changing the governor setting has the largest effect, but you could always redo the air intake and make a straight pipe for the exhaust, that would help a little. *Also the standard stuff like porting, carb adjustment, etc. can be done but I don't know to what extent or what effect (if any) it will have.
Old 09-07-2007, 12:24 AM   #3 (permalink)
You can remove the governor and advance the timing.
Old 09-07-2007, 01:27 AM   #4 (permalink)
I would be more interested in getting 2-3k more rpm out of some of these industrial motors.
hero_saku39 is offline   Reply With Quote
Old 09-07-2007, 02:57 AM   #5 (permalink)
i would like to turn around 6000 rpm safely all day
http://buggycentral.com
THUMPCRAFT is offline   Reply With Quote
Old 09-07-2007, 03:36 AM   #6 (permalink)
Super Moderator
http://www.performancevtwins.com/
That company can get lots of power and rpm's out of the engines for race applications, but I don't know how reliable it is. *Definitely not as reliable as a stock engine, but depending on the level of tuning probably still way better than a two smoke engine.
