#4 (permalink) |
Hey Bugpac,
Most 2 stroke engines automatically change the engine oil often, as it gets burned in the combustion chamber. * *Hi Yellowbeard, You will need to keep that engine in the airflow by offsetting the engine like traditional go-karts do (or the sidewinder mini-buggy by The Edge). *I would recommend you get a CHT gage (cylinder Heat Temperature) to monitor how hot the engine is. * /Frank
You know you are blessed when your wife loves you and she understands your need for tools and a shop! Coming Soon www.minibuggysupply.com |
#6 (permalink) |
EGT Is a good thing but spendy... keep air moving moving over it and you will be fine but you need to keep CLEAN air over it ...By what I mean by clean is non turbulant air ..you may need to create some air scoops and duct work...It makes for some wild looking buggies...If you check my adventure you'll see what i'm talking about on the 1st page...
EVIL 6's LOOSE CANNON |
#7 (permalink) | |
I can't disagree with you. *CHT (Cylinder Head Temperature) does not help carb. tuning much at all My thought was that a low-cost CHT setup (an analog Pyrometer and a spark plug washer thermocouple) would be a lot less expensive than an EGT gage and probe that are responsive enough to be useful. My experience with the air cooled Honda Odysseys was that once jetted reasonably well (using plug and piston wash), the CHT setup let the operator know two important things: 1) when the engine was up to operating temp ( so you don't cold seize the engine) and 2) know when the engine in general was heat soaked and still getting hotter. It can be done with an EGT, but it was more difficult to monitor while driving, as even part throttle will lower the EGT while still adding heat to an overheated engine. /Frank
