Old 12-02-2006, 02:39 AM   #1 (permalink)
dune's Avatar
Default FUEL CELL SETUP?
Looking for some advice on my fuel cell setup for the Rorty r82. I want to have the cell or cells custum built to better fit into the rear of the firewall. I also want to run two seperate cells. Only to increase the total carry load. Thes two tanks would act as one and have crossover lines. The draw would come from one but the fuel level would always be the same in both. I want this to work because of limited space and I want to be able to carry 10-12 gals if I choose for a mini type baja situation.
Am I asking for problems here or is this something that can work out????
Hit me with the details
dune is offline   Reply With Quote
Old 12-02-2006, 02:51 AM   #2 (permalink)
Default Re: FUEL CELL SETUP?
use a stock pump, no return line then, put the cap on one tank and the vent on the other, no need for 2 caps for tanks, isnt your car 1.25", if so, no need to worry about any baja racing...
Old 12-02-2006, 02:57 AM   #3 (permalink)
dune's Avatar
Hey bug, I am using the stock pump. When I said "mini type baja situation" That could mean: In my own mind(dreamer), Some sort of un-orginized race, Some event that may allow my car to run in an open class ect..... *Even if it does'nt qualify for a SCORE event. I want it to be able to function like a racer for the most part. Haul A$$ for a long time! *
Old 12-02-2006, 03:00 AM   #4 (permalink)
dune's Avatar
Also it would be cool to have dual filler locations, both sides of car
Old 12-02-2006, 03:08 AM   #5 (permalink)
thats cool, if you make the tank you can send to fuel safe for a bladder in it, have to talk with kfab for the contact info...the design looks good tho...
Old 12-02-2006, 03:10 AM   #6 (permalink)
dune's Avatar
Yeah, Isn't there a foam they make for the cells? Is this something that can be purchased and installed by the fabricator or after the tanks are built?
Old 12-02-2006, 03:13 AM   #7 (permalink)
you can buy foam yes, fuel safe is a bladder, summit has the foam...
Old 12-02-2006, 03:15 AM   #8 (permalink)
dune's Avatar
Cool!
Old 12-02-2006, 05:12 AM   #9 (permalink)
bdkw1's Avatar
The Fuel Safe bladders have foam in the as well. Do not buy the Summit foam, it is the same thing as Jazz. It will break up after about a year and cuase all sorts of problems. Go with ATL or Fuel Safe for foam.
Old 12-02-2006, 12:39 PM   #10 (permalink)
thats good to know bdk....
