Results 1 to 10 of 16
    R-1 engine cuts out
    Mar 2015
    Sandy Oregon
    I have a 2006 R1 engine in my buggy. At about half to full throttle the engine will cut out and then back on. It idles fine and below half throttle it runs good. I'm using an inline fuel pump rated at 45psi. Any ideas what could be causing this? Thanks.
    Re: R-1 engine cuts out
    Sep 2014
    West Palm Beach FL
    Blog Entries
    1
    The pump is rated at 45 PSI, but have you checked to see if it produces that? Do you know what the stock pump produced?
    Mar 2015
    Sandy Oregon
    I haven't checked to see if it produces 45psi. I believe the stock pump produces 42-43 psi. I'll need to get a fuel pressure gauge. Thanks
    Sep 2014
    West Palm Beach FL
    Blog Entries
    1
    If you have the stock tank and pump, is there any way to hook it up for a test?
    Jun 2015
    Texas Panhandle
    Always start with diagnostic codes.
    what you’re describing can be anything from a faulty fuel pump or clogged filter to a faulty tip sensor to about a thousand other things.
    Senior Member Linden318's Avatar
    Jun 2015
    Alberta, Canada
    I have the exact same engine in my Buggy. Im not experiencing the same Problem but my issue was the tip over sensor. My engine would run for 2 seconds and die, I figured out my tip over sensor was not in the up position which caused this. Maybe yours is just on the edge of level? Depending where its sitting? Otherwise, I would think it is a fuel pressure issue. Like you stated, a fuel pressure gauge would help you diagnose.
    fuel pressure needs to be at the 45psi at full throttle under full load, I had a clogged pickup screen which caused a similar issue.
    Mar 2015
    Sandy Oregon
    Thank you all for the suggestions. I'll keep you posted on what I find.
    Mar 2015
    Sandy Oregon
    I finally got a chance to work on the cut out problem. It was the tip over sensor. I took it apart and put a piece of foam in it to keep from moving.
    Jun 2015
    Alberta, Canada
    Good to hear. I had the exact same problem, so I think I will take my sensor apart and wedge it with foam as well!
    Thanks for the tip haha. Happy you got it running well.
  1. radius cuts
    By navanjr in forum Badland Buggy Group
    Last Post: 07-28-2012, 08:35 AM
  2. MEGALODON -Cuts
    By Y.O.R in forum Megalodon
    Last Post: 06-26-2012, 01:21 AM
  3. how to avoid miter cuts...
    By RoosterBooster in forum How To Do It
    Last Post: 05-27-2010, 01:55 PM
  4. making fish mouth cuts on tubing
    By wyattboche in forum Frame
    Last Post: 07-28-2009, 04:03 PM
  5. Handy tool for fishmouth cuts
    By bikelomen in forum Shop Talk
    Last Post: 05-21-2006, 08:31 PM
