Thread: Concours
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
    Re: Concours
    Depends on your desired tire size and if you want to go crawling. A reverse box in line between the bike motor and T-case would leave you low, but that's another 1K.
    Sami high range of 1.4X4.88=6.83 Decent for a 30" tire. Depending on what axles you run, you can get into the 6's on the R&P.
    Edit: read this..... http://www.pirate4x4.com/forum/gener...ggy-build.html
    Re: Concours
    Thanx for all the help. I haven't been able to find a stock diff with 4.88 hears. I have found subarus and BMWs that have 4.44. Which I believe is around a 6.2 final if running the samurai case. Is that going to be to tall, I don't ever do any kind of climbing. Mostly trail rides, occasionally I'll go to the dunes 15 miles from my house.
    Re: Concours
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    Suzuki Sidekick has a final drive ratio of 5.13:1. Independent front suspension also.
