Old 11-14-2012, 06:56 PM   #1 (permalink)
Default engine mounting help . please zr6r
Hi all im stuck on ideas on the best way to mount my zr6r engine into my frame if any users have any pictures or threads i could look at ? Detailed diagrams or anything that can push me in the right direction it would make my day . Please im on a dead build untill i get a little help
xd2cx is offline   Reply With Quote
Old 11-14-2012, 07:11 PM   #2 (permalink)
nutz4sand's Avatar
Default Re: engine mounting help . please zr6r
Mimicing the bikes stock tabs and building brackets to your frame is all thats needed.
Pics of your setup might help if you need more than that.
Oh look! A bunneh!
Old 11-14-2012, 08:23 PM   #3 (permalink)
Have a look on my first thread pal , id appriciate it
Old 11-14-2012, 08:33 PM   #4 (permalink)
quote;--------------------------------------------------------------------------------
Small update . . I have a guy coming to see me soon to knock up some custom engine mounts and hopefully have the engine in the rear soon , gunna grind off old rear sprocket and get the ninja sprocked banged on.
Are you going to use existing swingarm rear end, or redo the back. The motor will be happier with solid mount and not bouncing on that swingarm. Using same solid axle from buggy? Few more details from you will get a better answer.
CARLRIDDLE is offline   Reply With Quote
Old 11-14-2012, 08:41 PM   #5 (permalink)
The rear is staying as is , the bloke that was going to help didnt turn up and its been stood since , what info do you need . That may be easier
Old 11-14-2012, 09:18 PM   #6 (permalink)
Deranged's Avatar
Do a search for west Michigan shotgun build. There are pictures of my mounts. Keep in mind that you will have to remove the engine at sometime. Check it out .
Justin
Nowhere near the desert.
Deranged is offline   Reply With Quote
Old 11-14-2012, 09:55 PM   #7 (permalink)
Just had a look pal and its very well done but you have alot more room to play with and mine is a mich lower end budget are you on carbs?
Old 11-14-2012, 10:37 PM   #8 (permalink)
nutz4sand's Avatar
You can also simply look through the many builds on this site and see many guys motor mounts. They really are not that tough. Front end geometry is far FAR harder.
If you wish us to look at other posts of yours you might try providing a link to it in this thread.
I and many others are not likely to go reading all the posts of people asking questions just to see what they might (or might not have) have posted elsewhere.
If you think its important to the question you are asking either post links to the thread or psot new pics in this one. That will always lend you a much better help scene on this site you will find.
Oh look! A bunneh!
Old 11-14-2012, 11:41 PM   #9 (permalink)
Gotted's Avatar
Yea pal,
Put some pic's out and maybe you would get a better response or help (- the pal)
The only stupid question
is the question that isn't asked?
Gotted is offline   Reply With Quote
Old 11-14-2012, 11:47 PM   #10 (permalink)
nutz4sand's Avatar
Yah not sure where your from xd2cx but saying "pal" sounds like a bit of an annoyed start of a threat to most. It may be normal and commonplace where you live but its like a Taxi drivers insult to many of us! lol
Oh look! A bunneh!
Formula Desert Lites pride_in_motion Class Development 52 04-28-2011 06:13 PM
Why is Oil So Critical to My Engine? installers Cooling 1 03-06-2011 04:04 PM
Racing Cost & Information for each Class. TutTech MiniBuggy.net Lounge! 5 08-22-2010 03:22 PM
mounting a polaris engine jerry Motor - Engine 7 09-24-2008 02:21 AM
mounting a cvt on bike engine? Battleborn Driveline 26 09-05-2007 04:41 AM
