Results 1 to 10 of 10
    VW valve lash...
    Jul 2009
    Grand Rapids, MI
    Can anyone tell me what the valve lash should be on a typical air cooled VW 1915cc should be? About all I know is that it has an aftermarket cam in it. Are they typically a hydraulic or solid lifter?
    I'm a total noob to the VW engines....
    Re: VW valve lash...
    Petoskey, Michigan
    I cannot help on the VW stuff as I won't mess with it anymore. But these guys are some VW nuts if you are gonna play with VWs they can help!
    BuggyTalk - Message Index
    And this link is where they buy and sell moslty VW items.
    BuggyTrader
    Jul 2009
    Grand Rapids, MI
    Thanks Nutz! I found what I needed over there...
    Depends, aluminum push rods or steel...........
    Jul 2009
    Grand Rapids, MI
    They are steel....
    According to the info that I found on the other site, I should set them to a "loose zero" when cold... does that sound about right?
    Yup, you should still be able to rotate them but not feel any slop.
    May 2009
    Alta Loma Ca
    That's the way I used to set mine, with a big cam they wouldn't idle for beans cold. Amazing transition when they'd warm up. Some of the later models did have hydraulics, but the guys I knew would sleeve them down for solids. They said it was stronger.....they told me this after I missed a shift and chunked out a lifter bore Things you learn. Never sleeved them (not cost effective)just learned to make sure I knew how to shift!
    ...it's only a flesh wound...
    Jul 2009
    Grand Rapids, MI
    Thanks for the tips guys!
    San Diego
    Not to overstate the obvious but better loose than tight. German engineers are very very smart and if you stop and think about what is happening during the warm-up and running of the air-cooled vw motor it is amazing that they run as well as they do for as long as they do. The German engineers realized that they need the motor to expand equally as it warms up. If the jugs/retaining studs expand faster than the pushrods it is a very noisy motor, if the pushrods expand faster than the jugs, the valves wont seat and it does not run very well.
    All true except T1's came from the factory with aluminum push rods. This is why the stockers require .006-.008 clearance.......... With the steel push rods they expand at the same rate as the jugs, no real clearance needed. All you have to watch out for is case and head expansion.
  1. Brake proportioning valve selection
    By andy777bmx in forum Controls and electrical
    Last Post: 09-13-2011, 08:46 PM
  2. Blow off valve question.
    By yummi in forum Motor - Engine
    Last Post: 06-29-2008, 08:13 AM
  3. few CVT q's...
    Last Post: 02-03-2008, 04:47 AM
  4. Proportioning Valve and distribution block question
    By griff in forum Suspension - Wheels & Tires
    Last Post: 06-29-2007, 06:11 PM
  5. Brake Proportioning Valve
    By GaryMX in forum Controls and electrical
    Last Post: 02-22-2007, 10:01 PM
