Old 12-20-2009, 02:39 PM   #1 (permalink)
Default clutch replacement
hi guys
just wanted to ask what would be a clutch replacement for my buggie. it has a gsxr 1000? go to mostly the dunes.
thanks r6eric
r6eric is offline   Reply With Quote
Old 12-20-2009, 04:36 PM   #2 (permalink)
Admin
Gene's Avatar
Default Re: clutch replacement
Opinions vary. You could get a Barnett clutch and alternate heavy duty and stock springs or do the same with a stock clutch. That's what most of us are running in the NW.
Old 12-20-2009, 04:49 PM   #3 (permalink)
busasandrail's Avatar
Always use the stock clutch, fibers and steels, they seem to be the best and last the longest. Also upgrading your springs is a good idea and will help the longevity of the clutch, just make sure you get a clutch slave support of some kind. Otherwise youll break the clutch slave cover.
Old 12-20-2009, 11:51 PM   #4 (permalink)
hey gene and busasandrail
thanks for the info just dont understand the stock springs and heavy duty springs. sorry guys first buggie ever owned and still learning.
thanks r6eric
CVT Drive clutch for Briggs DAWG Driveline 3 11-25-2009 04:14 AM
Busa motor flywheel. masterfabr Driveline 44 06-15-2009 06:31 PM
Hydaulic Clutch : R1 Need Help ghettosled Controls and electrical 8 02-03-2009 03:29 PM
Driven CVT Clutch to Gearbox Mating SCBaja Driveline 18 11-11-2008 12:25 AM
Hand clutch Ideas... whiplash Controls and electrical 14 02-12-2008 02:53 PM
