Old 11-03-2009, 05:47 PM   #11 (permalink)
Default Re: Mounting a ZZR1100 in a Piranha
I agree, just raise the motor up until the oil pan is above the bottom of the lower frame rail. Or do a search and see if anyone makes a shallow oil pan for that motor. You may need to run an idler sprocket to keep the chain away from the engine case when you raise the motor up though. Not a big deal if you do it right. IMO you should extend the engine bay at least 100mm on a Piranha.
RickS. is offline   Reply With Quote
Piranha double a front module RickS. Projects in Progress 101 11-14-2009 04:43 PM
Piranha Suspension Hyperthetical Question nelson15 Suspension - Wheels & Tires 12 10-28-2009 11:50 PM
RPM mounting question furtelli Driveline 6 05-08-2009 12:55 AM
mounting a polaris engine jerry Motor - Engine 7 09-24-2008 03:21 AM
Beard seat mounting dimensions anyone? Rorty MiniBuggy.net Lounge! 0 06-01-2007 04:35 AM
