#11 (permalink) |
Yeah, "diff" isn't the right word thus the quotes but really a 90 degree gearbox is what you want. The general consensus is no diff is needed for offroad unless you want cutting brakes. Just have to overcome all the other issues
#13 (permalink) |
As stated in my above post on the previous page the motor cycles 90 degree drive is a big pain in the tail IF you are trying to drive two wheels with it.
Be easier to simply go with a diff from a car. Get a posi unit if you are worried about a diff action or weld it up.
#14 (permalink) |
I was in the same situation and am using a 79 Yamaha XS1100 engine(shaft drive)in my buggy. It is driving via chain into a Subaru differential. It has actually worked out just fine so far and I retained the Subaru axles, disc brakes, wheel bearings, wheel flanges etc. The engine is mounted backwards and I am using the rear differential from the Subaru.
| motorcycle enine with a drive shaft | bigwaves311 | Driveline | 7 | 01-28-2009 05:48 PM |
| Why are there no shaft drive finals? | opsled | Driveline | 15 | 12-20-2008 10:24 PM |
| snowmobile drive clutch pto shaft taper | LEE1969GB | Driveline | 2 | 03-15-2008 03:14 PM |
| who makes a input shaft drive w/ reverse differential? | camshaw | Driveline | 5 | 01-09-2007 09:41 PM |
| center drive , shaft size | actcrazy | Driveline | 18 | 11-30-2006 07:28 PM |
