Old 10-14-2009, 02:36 AM   #1 (permalink)
Default Odd motor sound
I got the engine (04 Busa) fired up this evening after sitting for 8 or 9 months and after it settled in I am hearing what sounds like a dry cam drive chain, no shreaking or metallic sounds just sounds like something rubbing against hard rubber/plastic. Oil level looks fine so ... any ideas?
Glamisman is offline   Reply With Quote
Old 10-17-2009, 02:45 AM   #2 (permalink)
Admin
Gene's Avatar
Default Re: Odd motor sound
Oil pressure at idle and higher RPM?
