Old 09-24-2009, 02:26 AM   #1 (permalink)
Default FL250 Problems I need some help!!
I bought a fl250 about a year ago and it would start and run but it would not move. when you would give it some gas it bogs down and still does not move. i have replaced the fuel tank, carburetor and fuel pump. i need some help on this.
Doink is offline   Reply With Quote
Old 09-24-2009, 02:28 AM   #2 (permalink)
Default Re: FL250 Problems I need some help!!
the clutch is moving the whole time the motor is just not getting enough power for it to engage on the belt
Old 09-24-2009, 07:31 AM   #3 (permalink)
nutz4sand's Avatar
Welcome to the site.
First off do you know the compression the motor has in PSI?
Second are you SURE the exhaust is not plugged? You can pop it off and try it for a few seconds with it off but any longer is just gonna piss off the neihbors more. Mice like to build nests in them. If its plugged it will do what you describe.
You did not mention it but can you push it around and see the secondary clutch or driven clutch spin while you push it? Just asking to know the drivetrain aint locked up.
Sand! The only gold I need!
Old 09-25-2009, 12:25 AM   #4 (permalink)
it has 150 psi it does it with the muffler off of it i live in the country so while i was working on it i left it off and i dont know about the drive train right not i have it in the shop and they cant figure it out either but what the real stumper is is that the carb is just dumping fuel
Old 09-25-2009, 12:26 AM   #5 (permalink)
i will call them tomorrow and figure out if it moves or not
Old 09-25-2009, 12:46 AM   #6 (permalink)
nutz4sand's Avatar
If the carb is just dumping fuel your float or needle and seat is bad or in wrong. Often its easy to get the float on the wrong side of the needle.
The carbs got to be clean and right or you will never get a two stroke to run decent.
Old 09-25-2009, 07:02 PM   #7 (permalink)
its a brand new carb and it came to me built
Old 09-25-2009, 07:03 PM   #8 (permalink)
the shop looked it over and said it is correct and the secondary clutch is good
Old 09-26-2009, 02:07 AM   #9 (permalink)
nutz4sand's Avatar
If the carb is dumping fuel it needs attention. The only way fuel gets past a carb is the float or needle and seat are bad or its setup for gravtiy feed pressure and you got a pump thats capable of forcing fuel past the needle and seat.
What I am guessing at here is the carbs way overloaded with fuel due this issue and when you gas it as the slide and the needle valve moves up out of the way there is soooo much fuel its loading the motor down.
FL250 parts for sale PilotHawK For Sale 16 02-20-2010 03:32 AM
custom fl250 bumper question fl250driver The Pilot & Odyssey Forum 2 10-07-2009 05:16 PM
Honda FL250 EEE Frame in San Diego Fugaboo For Sale 0 04-05-2009 05:23 AM
fl250 stock power OzDamian Motor - Engine 6 11-18-2008 07:33 PM
honda odyssey overheating problems fl250dirtslinger The Pilot & Odyssey Forum 3 10-27-2008 11:31 PM
