Hi guys,
I got my hayabusa powered Smart Car running last weekend, now I am just trying to get some bugs worked out. Could somebody please tell me which wire is for the tach lead on an 05 Hayabusa, I am running a Koso gauge cluster, all of the wires I have tried from the original Busa gauge cluster don't seem to work, I am thinking it must be a wire out of the CDI box or something. Any help is much appreciated. ![]() Thanks, Matt |
Its the yellow/blue(tracer)wire if you have a tach setup to run with the two pulse motorcycle signal. If not Tach Adapter, 4 coil system * Schnitz Motorsports Inc this will get you your 4 pulse signal.
It depends on what your tach needs. Also did you figure out why your engine was running so poorly?
Being pushed to better yourself is never a bad thing. EL TORO sand car w/ intercooled TURBO 1397 Busa / Subaru STI diff. / cutting brakes |
#4 (permalink) |
Thanks, It turns out that the gauge is programmable, I am going to take another look at it tomorrow.
It is running pretty good now, I had a bad computer at first, replaced it and ran tons better. I took it to a motorcycle tuner and he thru 30 percent more fuel at it just for safety's sake for now until we get it on a dyno. I am working on fitting the stock airbox also, I think that will really help the thing run better and give it a little more torque. |
| Hayabusa Engine | Vegas Rider | Motor - Engine | 1 | 01-22-2009 01:00 AM |
| hayabusa stand | 1982shawn | MiniBuggy.net Lounge! | 3 | 04-13-2008 12:56 AM |
| FEDERAL Sandrail For Sale - Hayabusa Powered - $33,950 | FEDERAL | For Sale | 53 | 08-24-2007 05:28 PM |
| FEDERAL Turn-Key Hayabusa Powerered Long-Travel Sandrails | FEDERAL | Turnkey buggies and sand rails | 7 | 07-03-2007 04:29 PM |
| Hayabusa MPH Gearing Chart | HarveyMushman | Motor - Engine | 2 | 03-01-2007 04:58 AM |
