Old 08-30-2009, 04:23 AM   #11 (permalink)
Admin
Gene's Avatar
Default Re: FZ1 swap, The madness starts
Looks good. How many chain links did you gain leaning the RPM back?
Old 08-30-2009, 11:38 PM   #12 (permalink)
With the old chain in for mock-up I get 28 plates. I may get a couple more when I set up the idler sproket. Not as long as I would like but should be ok for a pampered play toy.
Now I need to fix the seal around the FNR shifter. At the new angle it is leaking a bit. but I know I have too much gear oil in it right now.
Dezzrats is offline   Reply With Quote
Old 10-05-2009, 12:13 AM   #13 (permalink)
Little more work done. Exhaust mocked up with a S&S YT-40 cut down a little. I added a RCI 5gal fuel cell to support the fuel injection. Did some beef-up on the trailing arms, and new brake lines.
Old 10-05-2009, 12:15 AM   #14 (permalink)
pics
Old 10-05-2009, 12:16 AM   #15 (permalink)
more pics
Old 10-05-2009, 12:17 AM   #16 (permalink)
and thee more
Old 10-05-2009, 01:01 AM   #17 (permalink)
Admin
Gene's Avatar
Coming along nicely. Pipes look good and trailing arm modification looks strong.
Old 10-06-2009, 03:12 AM   #18 (permalink)
jumpin jellybean's Avatar
sweet looking build keep up the great work
Old 10-06-2009, 12:48 PM   #19 (permalink)
Administrator
K-fab's Avatar
Like Gene said - pipes and arms look really good.
There is one thing that sort of stands out to me and I'm not quite sure how I'd fix it.
The lower, front tranny mount - tubes coming out of the bottom frame rail with the mounting tab on the end. That's one big lever arm - there's nothing to combat it moving.
About the only way I can think of to modify it to make sure it doesn't move is put a couple of kickers between the rear cross brace and the ends of those tubes. That will shore everything up a little more. It's only a couple of short tubes, but it will box out that area a bit more.
It may be overkill, but with a chain drive, the last thing you want it to flex a mount and get the chain out of alignment. The poor thing's already abused just by virtue of only being a couple feet long, so anything you can do to combat any sort of flex and extra stress on the chain would be worth it.
Old 10-06-2009, 02:36 PM   #20 (permalink)
K-fab, I see what you are saying.........That's why it's posted here. The gear box will want to move in the direction of the chain rotation under torque.
I will be looking into a couple of more tubes down there.
R1 motor swap randybrinsley Motor - Engine 14 07-22-2009 02:56 PM
yamabuggy and engine swap eyco MiniBuggy.net Lounge! 1 06-30-2009 02:36 AM
Ease of motor swap johnny73 The Pilot & Odyssey Forum 17 01-01-2009 08:05 PM
2000 ZX9 Engine for RZR swap? Any good? whiplash Motor - Engine 10 12-28-2007 04:06 AM
EEE Buggy Motor Swap To CBR954 gunnner651 Motor - Engine 12 11-08-2007 02:46 AM
