Old 07-23-2009, 08:01 PM   #1 (permalink)
Default mounting a CBR600RR motor to the frame
Hey, I have a chenowth which used to have a bug powertrain, but that blew up and Ive decided to put a 600RR one in instead of rebuilding. I was wondering would it be a decent idea (if possible) to chop off a few bits of the CBR's frame that I did not need then weld it to the frame then make some support bars? I thought of this because 1. the frame is pretty light and its hollow 2. I wont have to spend $$ on pipe and gas to fab up another solution. 3. Save time.
Maybe its blind optimism but I figured Id pass it through you guys anyway
Heres the buggy:
And heres what the frame looks like. All I need are the trans+motor mounts from it, not the top peices :
Any help is appreciated
Thanks
-Sebastian
ubercooper is offline   Reply With Quote
Old 07-23-2009, 08:09 PM   #2 (permalink)
Administrator
K-fab's Avatar
Default Re: mounting a CBR600RR motor to the frame
How do you plan on welding the bike's frame to the chassis? Bike frame is aluminum, and I doubt that the chassis is.
Old 07-26-2009, 07:20 PM   #3 (permalink)
Looks like an R1 or Busa would be a little more suitable for that size of a build....
Mopar is offline   Reply With Quote
Old 07-26-2009, 08:08 PM   #4 (permalink)
Admin
Gene's Avatar
It's easy to make motor mounts out of flat plate or tubing. I'd skip using the aluminim subframe other than gathering dimensions.
Old 08-05-2009, 08:03 PM   #5 (permalink)
yeah that was my first choice after a zx-14 motor unfortunately there about 4x as much $ as one from a friends wrecked cbr600rr
how well will that hold up offroad? also besides rubber bushings how could that be designed to minimize shock?
Thanks
-seb
Old 08-06-2009, 02:06 AM   #6 (permalink)
Admin
Gene's Avatar
Most of us hard mount the engine because we don't want it moving around affecting chain alignment.
I need to bring ny camera home to get some pictures of flat plate I had laser cut for my Hayabusa cylinder head. It's a keyed design and will work very well off road.
My first car (see Another Mini in Projects for Progress) uses 1.25 diamter tubing and mounting tabs. Works well.
Old 10-19-2009, 04:14 AM   #7 (permalink)
I think it's an interesting concept. Wondering how you are going to connect the engine to the rear wheels? Chain drive and sprocket or an adapter to the Vdub trans? Doc
docteriffic is offline   Reply With Quote
Old 10-21-2009, 06:27 PM   #8 (permalink)
Why not just rebuild the engine? thats what I would do.
Old 10-22-2009, 07:42 PM   #9 (permalink)
jumpin jellybean's Avatar
what trans is in it if bus tranny you can hook up almost any four cylinder engine with adapter plate just my $0.02
off road buggy space frame roco Projects in Progress 21 08-17-2009 04:36 PM
2 seat mini Prototype frame TutTech For Sale 12 04-13-2009 02:08 PM
Mounting on frame. lekhu88 Frame 6 09-30-2008 12:31 PM
Frame Idea 2 plkracer The Drawing Room 21 05-04-2008 04:47 AM
Ouch. The results of a tired chromoly frame... K-fab MiniBuggy.net Lounge! 41 02-18-2007 04:36 PM
