Old 07-01-2009, 05:32 AM   #1 (permalink)
Default where to get exhaust tubing for busa
I was wondring where you guys get the tubing to make your exhaust i have a stock header and i want to cut it and make it work. is there some place that sells pipe and j bends
Graves1 is offline   Reply With Quote
Old 07-01-2009, 05:36 AM   #2 (permalink)
Admin
Gene's Avatar
Default Re: where to get exhaust tubing for busa
You may not be able to weld to the stock header unless you use exactly the same material. Might be titanium or unobtanium for that matter.
Burns stainless sells tubing but you might do better with mild steel exhaust tubing, Have you checked the Chassis Shop?
Tubing & Bends at The Chassis Shop
Old 07-01-2009, 05:42 AM   #3 (permalink)
No but i will ,what do you do about the flange to seat the pipe in the head
Old 07-01-2009, 05:45 AM   #4 (permalink)
how do you tell what metal it is
Old 07-01-2009, 02:07 PM   #5 (permalink)
Administrator
K-fab's Avatar
If it's stock, go check Suzuki's web site and see what they say about the machine and it's specs. It may state Ti exhaust, if it is. Do some searching on the motorcycle in magazine articles too.
Stick a magnet to it. If it sticks, it's mild. If not, it's stainless or Ti. If the header's off the bike, pick it up. If it's nice and light, it's Ti. If it's fairly heavy, and the magnet doesn't stick, it's stainless.
For exhaust parts - tubing, bends, all sorts of stuff, check out SPD. They carry everything you could need to make an exhaust system. (I just ordered stuff to finish my exhaust from them yesterday).
Old 07-01-2009, 04:27 PM   #6 (permalink)
Try Schoenfeld Headers - Manufacturer of competition headers
Badride is offline   Reply With Quote
Old 07-04-2009, 04:10 AM   #7 (permalink)
the magnet sticks so i guess i will cut it and get some tube and make it work thanks for the help
Tubing Size Thickness Lavender Sidebottom Frame 4 06-18-2009 03:12 AM
Aluminum tubing? johndoe Frame 9 05-14-2009 08:16 PM
Frame tubing question... Wheels Frame 12 02-28-2009 10:49 PM
All your tubing sizes (weldments) standfast File Library 0 06-20-2008 07:09 AM
800 rotax exhaust size LEE1969GB Motor - Engine 1 10-27-2007 02:48 PM
